CAYC, Verbrauch hoch, Reg. zu oft, kein Fehler im MSG | Posts 16+
Go to page: Previous  1, 2
ZEHST
Karma: +0 / -1   Thank you, like it!
Post13-10-2025, 19:59    Subject: Quote
Good evening.
Here's some information about what you can see/read using VCDS.
There are so many differences, so I've included them in the attachment below.
Enhanced features:
- 04 Basic settings
- 03 Actuator diagnostics
Basic functions:
- A complete list of IDE extended measurement values with units.
The list includes 638 data rows.
I created the list myself, and it "took" icon_cool.gif some time.
With this list, I don't always have to be directly connected to the MSG.
Compose searches/queries easily on your computer.
Note: This list is only for...
- Passat, 3C, B6, manufactured in 2010.
- Engine, 1.6 TDI CR, CAYC
- MSG (Engine Control Module) from Conti, part number 03l906023GL.
- Software 9979
Read with VCDS, version 25.3.1, HEX-V2.
The VCDS display/output is NOT the same.
It must be examined carefully; the IDE numbers are not transferable.
Always check the measurement text and the abbreviation.
Significant differences exist between CAN extended diagnostic values and UDS, with UDS only supporting extended diagnostic values.
The statement "simply read IDE XXXVVV" is not a complete requirement.
because this statement is not clear.
I wouldn't have thought so.
In addition to that, some of my measurements are being displayed twice.
but with different IDE numbers and different naming conventions.
I couldn't find anything about it, I have no idea.
Does anyone have an explanation for this? Please write it out.
best regards
Stellglieddiagnose 03.pdf
 File name:  Stellglieddiagnose 03.pdf
 File size:  532.22 KB
 Downloaded:  184 times
Grundeinstellung 04.pdf
 File name:  Grundeinstellung 04.pdf
 File size:  255.96 KB
 Downloaded:  135 times
Tabelle 000-VCDS_IDE_Messwerte_ausgelesen_Dieselschrauber.xlsx
 File name:  Tabelle 000-VCDS_IDE_Messwerte_ausgelesen_Dieselschrauber.xlsx
 File size:  43 KB
 Downloaded:  416 times
Translated on 05-07-2026, 3:55.
dieselschrauber likes this.
Post13-10-2025, 21:56    Subject: Quote
Why aren't you addressing our suggestions?
You have very little knowledge, but you try to appear particularly clever and you exploit that perception.
That also explains the frenzy of parts replacements and repairs, which must have already cost a four-digit sum.
If you continue like this, this thread will become pointless.
Translated on 05-07-2026, 3:58.
ZEHST
Post18-10-2025, 16:43    Subject: Quote
Please find the requested information attached.
- Autoscan
The rest follows icon_cool.gif.
377857km_-_13.10.2025_autoscan.pdf
 File name:  377857km_-_13.10.2025_autoscan.pdf
 File size:  69.43 KB
 Downloaded:  167 times
ZEHST
Post18-10-2025, 17:12    Subject: Quote
As requested by Herbert on October 11, 2025:
and then a recording (snapshot) with
Speed.
Engine temperature.
Medium injection quantity.
Fuel injection quantity deviations
Rest folgt.
Anfrage Herbert _ 001 _ 11.10.2025.pdf
 File name:  Anfrage Herbert _ 001 _ 11.10.2025.pdf
 File size:  281.41 KB
 Downloaded:  103 times
Translated on 05-07-2026, 3:59.
ZEHST
Post18-10-2025, 19:55    Subject: Quote
As requested by Herbert, dated October 11, 2025.
Your values look good,
but the median EM value is missing.
and that's when I had already wondered about your low fuel consumption.
I have processed the data, please see the attachment.
Anfrage Herbert _ 002 _ 11.10.2025.pdf
 File name:  Anfrage Herbert _ 002 _ 11.10.2025.pdf
 File size:  341.83 KB
 Downloaded:  139 times
Translated on 05-07-2026, 4:00.
No new posts High consumption General Tips
No new posts 1.4 TSI CTHA - Fuel consumption figures Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehlercode 539 AFN nur Vmax 180! Verbrauch zu hoch! Diesel Engine Technology
No new posts BMW 525d: High Fuel Consumption? Find Out Why. Diesel Engine Technology
No new posts A6 TDI Avant 1.9, manufactured in 08/2002, making noise a... Diesel Engine Technology
No new posts Motorstörung (rotes Blinken) aber kein Fehler gespeichert Diesel Engine Technology
