DSG DQ200: Clutch Repair - Workshop Recommendation
dieselschrauber likes this.
Post28-04-2026, 12:00    Subject: DSG DQ200: Clutch Repair - Workshop Recommendation Quote
Summary: Does anyone know a cheap workshop that can replace the DQ200 clutch discs?
My DQ200 from 2014 has recently been reporting:
Code:
21211 - Gangsteller 4 nicht regelbar            P176D 00 [10001000] - -
Most of the time, after switching from R (Drive) to D (Reverse), the error message "Gear malfunction, Reverse gear not available" appears. Then only gears 1, 3, 5, and 7 will function.
The (easily replaceable) memory module was replaced (after a previous failure) two years ago.
I suspect that the "Schlupfperlen" for the double switch fork for 6/R are now being installed. The repair is too complicated for me to do myself (even if I were able to).
Inquiry with a local gearbox specialist in the far north resulted in a quote of 4,400€. Request in the area approximately 500km south of Cologne resulted in a payment of 2400€.
Has anyone had good experiences with a more affordable provider? Possibly somewhere near the border, such as in Poland or elsewhere?
The car is over 10 years old and has over 250,000 km. Residual value intact, probably around €5,000... Selling the item as "defective" could also be an option, if someone knows of good "flippers" (people who buy and resell used items).
Thank you for your tips.
Guste
dieselschrauber and brezelmann01 likes this.
Post04-05-2026, 21:00    Subject: DSG DQ200: Clutch Repair - Workshop Recommendation Quote
Hello everyone,
The car was sold today. The request has been completed.
If anyone of you is experiencing similar problems:
Almost simultaneously with the sale, the company MWG Getriebeservice (from the area west of Kassel) contacted us.
They provided excellent advice and offered very affordable prices. Unfortunately, the sale was already finalized, so I couldn't take advantage of it myself. But the contact and the price were so good that I'm a little annoyed that the car wasn't repaired (and then sold for a much higher price).
Maybe it will be helpful for one of you someday.
No new posts DSG DQ200 failure Transmission, Chassis, Body & Interior
No new posts DQ200 DSG Problems: Common Issues & Fixes On-Board Diagnostics (OBD)
No new posts DQ200 Problems: Common Issues & Solutions Transmission, Chassis, Body & Interior
No new posts Battery charger recommendations Electrical Systems, Vehicle Electronics, Multimedia
