Coding trailer hitch, missing SFD tokens
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
AlexBuchner18
Post17-06-2026, 20:27    Subject: Coding trailer hitch, missing SFD tokens Quote
Hello everyone,
Today, I installed a tow hitch on a Skoda Octavia (manufactured in 2022). Unfortunately, I was unable to perform the required coding because the control unit is locked and the message "Missing tokens" is displayed.
Has anyone else experienced a similar problem, or does anyone know how to proceed with the encoding?
Thank you in advance for your support!
Vehicle Identification Number: TMBJW8NX9PY010190 License plate:
Gateway part list: 5WA 907 530 L.
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
10-Parking assist -- Status: Error 0010.
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
23-Brake force amplifier -- Status: OK 0000
2B steering column lock. -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B Multifunction Device -- Status: OK 0000
51-Electric drive -- Status: OK 0000.
52-door electric. Front passenger seat. -- Status: OK 0000.
5F-Information Selection. I -- Status: Error 0010
75-Telematics -- Status: OK 0000
8C High-Voltage Battery Management -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: Error 0010.
Rear left door electronics -- Status: unreachable 0100.
Rear right-side door electronics -- Status: unreachable 0100.
C6 battery charger -- Status: OK 0000
D6-Left lighting control 2 -- Status: OK 0000
D7-Light control, right side, 2 -- Status: OK 0000.
811E Burglar Protection - Status: OK 0000
811F Burglar Protection System -- Status: Operational 0000.
8120-Burglary Protection System -- Status: Operational 0000
8121-Burglary protection HR -- Status: OK 0000
Karma: +782 / -0   Thank you, like it!
Post17-06-2026, 21:35    Subject: Coding trailer hitch, missing SFD tokens Quote
Okay, the current status is:
https://community.dieselschrauber.org/en/viewtopic.php?t=31009
SFD: Yes/No:
https://community.dieselschrauber.org/en/viewtopic.php?t=31954
SFD Unlock: Yes/No
https://community.dieselschrauber.org/en/viewtopic.php?t=31953
If you've made it this far, please query the SFD data from the relevant control unit and send it to me along with the Autoscan results.
No new posts Coding the service interval display on Golf III Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Anhängerkupplung nachrüsten im Passat 3C, MJ 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Anhängerkupplung freischalten, neuere Fahrzeuge ab Golf5 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts fehlende Leistung bis 2.500 Diesel Engine Technology
No new posts Logfile fehlende LD bei ein AKN Upload
No new posts fehlende endgeschwindigkeit a6 2,tdi, probs log auszuwerten On-Board Diagnostics (OBD)
No new posts 1Z Golf occasionally stalls (lack of control voltage at t... Diesel Engine Technology
