Polo 6R - Exhaust pipe with throttle valve unit - where to buy?
stolley
Karma: +38 / -1   Thank you, like it!
Post04-07-2026, 13:32    Subject: Polo 6R - Exhaust pipe with throttle valve unit - where to buy? Quote
Hello everyone,
The exhaust pipe, including the valve control unit (part number 6C0253101E), on my daughter's Polo 6R is rusted through. I will add a photo later.
I have already inquired at icon_biggrin.gif, and the price of the item there is 400 €. However, they also have a delivery time of 1 to 2 weeks. It seems this part is not available from alternative suppliers – I've been searching for ages and have been corresponding back and forth with Autodoc's customer service.
My question to you: Have you ever encountered the problem of not being able to get a part at a reasonable price and quickly? Do you happen to know if there's a three-piece solution available? I mean, an exhaust pipe - valve - exhaust pipe combination? Or could you recommend a dealer where I can order genuine VW parts online?
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
Translated on 04-07-2026, 13:35.
Karma: +784 / -0   Thank you, like it!
Post04-07-2026, 14:20    Subject: Polo 6R - Exhaust pipe with throttle valve unit - where to buy? Quote
If I enter the part number 6C0253101E on auto-doc.at, will I get multiple results?
What is this "tax evasion unit" about? The product images look like they're just showing a regular trouser leg.
Translated on 05-07-2026, 11:34.
stolley
huebi likes this.
Post04-07-2026, 15:45    Subject: Polo 6R - Exhaust pipe with throttle valve unit - where to buy? Quote
Hello Rainer,
That's the problem, but it might also be due to an incorrect part number.
On eBay, you can find what is called the "exhaust manifold pipe including the exhaust flap control unit J883," but it is actually listed under that specific part number. When you enter the search term in quotation marks, my Google search results show a Facebook post listing that exact part. Attached is also a photo.
It can be seen that the control unit is a welded component inside the trouser leg. I think it's really stupid.
 Die Schelle stellt nur eine sehr notdürftige Übergangslösung dar.
 File size:  3.26 MB
 Viewed:  47 times
Translated on 04-07-2026, 15:46.
Karma: +436 / -0   Thank you, like it!
dieselschrauber likes this.
Post06-07-2026, 12:39    Subject: Polo 6R - Exhaust pipe with throttle valve unit - where to buy? Quote
According to the VW program, the part number you mentioned includes the exhaust flap and the actuator.
In addition, 5Q0 253 692 B is available as a repair kit for the exhaust flap.
If online retailers or independent sellers list the part number you mentioned, I would expect that it is the correct pipe (even if the photo is not original), but possibly without the control valve. If the valve and actuator are still in good condition (and only the connecting pipe is damaged), I would buy a replacement part from a regular retailer and reuse the other components from your existing pipe.
Translated on 06-07-2026, 12:42.
Post06-07-2026, 13:32    Subject: Polo 6R - Exhaust pipe with throttle valve unit - where to buy? Quote
The pipe behind the valve looks quite reddish icon_cool.gif. I think it's probably not a good idea to reuse it.
Translated on 06-07-2026, 13:33.
stolley
huebi likes this.
Post06-07-2026, 13:41    Subject: Polo 6R - Exhaust pipe with throttle valve unit - where to buy? Quote
Rainer is right:
I've just decided to order the lower tube assembly, including the welded-on flap, from the dealer because everything is looking pretty rusty.
But what a design flaw: To weld a bypass valve into the exhaust system?!
Thank you very much for your support!
Translated on 06-07-2026, 13:42.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kombiinstrument Polo 1998 bis 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kombiinstrument Polo ab 10.99 bis 09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust pipe for auxiliary heater Transmission, Chassis, Body & Interior
No new posts LMM Wo kaufen? Diesel Engine Technology
No new posts Buy Turbocharger Diesel Engine Technology
No new posts ASZ Motor mit um 250 TKM kaufen Diesel Engine Technology
