Persistent DPF regeneration after timing belt replacement
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Dieselschrauber Bar
Marco_mk75
Post13-07-2026, 20:04    Subject: Persistent DPF regeneration after timing belt replacement Quote
Volkswagen Golf 7 1.6 TDI DDYA, 175,000 km, mostly highway miles.
Hello everyone.
I replaced the timing belt on my Golf 7 1.6 TDI. I loosened the pulleys of the high-pressure pump and camshaft, rotated them to their respective marks, installed the belt, and then tensioned it. Now, the pulleys are not aligned with their marks, which is how they should be.
I checked the error memory, but there's nothing stored in it.
Only he starts regenerating now, and it doesn't stop even after a long drive.
All the connectors are plugged in, and the hoses of the differential pressure sensor are not kinked or damaged.
Does anyone know what might be causing this?
Translated on 13-07-2026, 22:28.
Karma: +787 / -0   Thank you, like it!
Post13-07-2026, 22:27    Subject: Persistent DPF regeneration after timing belt replacement Quote
Sure:
Reasons why the DPF is not regenerating
Translated on 15-07-2026, 11:48.
Marco_mk75
Post13-07-2026, 22:43    Subject: Persistent DPF regeneration after timing belt replacement Quote
That happened right after the timing belt was replaced, so I drove about 125 miles (200 km) and it started happening immediately.
Translated on 13-07-2026, 22:43.
Karma: +1323 / -0   Thank you, like it!
Post14-07-2026, 6:24    Subject: Persistent DPF regeneration after timing belt replacement Quote
Hi there,
Have you double-checked the valve timing by using shims?
Does the engine regenerate, or is it only running at a higher RPM (due to air conditioning, energy management)? You can check this, for example, by reading the data from the particulate filter in the "Advanced Measurement Data" (soot load, distance since last regeneration). The regeneration status should also be visible there.
Knowing the model year and engine code would be helpful; then I might be able to compare it with my own vehicle's data.
During the timing chain replacement, an exhaust temperature sensor likely had to be removed. Does it still provide meaningful readings? It's possible that the post-injection system is running constantly because the sensor is reporting a temperature that is too low. The differential pressure sensor was probably also affected.
Translated on 14-07-2026, 6:57.
Marco_mk75
Post14-07-2026, 7:32    Subject: Persistent DPF regeneration after timing belt replacement Quote
This is a DDYA engine, manufactured in 2018, and the error memory is clear.
Translated on 14-07-2026, 7:32.
Marco_mk75
Post14-07-2026, 7:58    Subject: Persistent DPF regeneration after timing belt replacement Quote
What are the sensors in the measurement unit? Also, what is a "Launch device"?
Translated on 14-07-2026, 7:58.
Post14-07-2026, 16:02    Subject: Persistent DPF regeneration after timing belt replacement Quote
It's probably difficult to directly infer information from VCDS and apply it to a Launch diagnostic tool (which specific model?). Is there a list of available data parameters that can be accessed while the vehicle is running or with the ignition on?
Translated on 14-07-2026, 16:03.
Marco_mk75
Post14-07-2026, 17:21    Subject: Persistent DPF regeneration after timing belt replacement Quote
Can I tell you right away?
Marco_mk75
Post15-07-2026, 18:53    Subject: Persistent DPF regeneration after timing belt replacement Quote
I'll double-check the timing settings on Saturday. The problem was also that the engine was still slightly warm, which isn't ideal.
Translated on 15-07-2026, 18:53.
No new posts Windshield Wiper Regeneration General Tips
No new posts 1.6l CR-TDI, frequent regeneration / Diesel particulate f... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Regeneration nach km Diesel Engine Technology
No new posts Noise after timing belt replacement Diesel Engine Technology
No new posts Spannrollenproblem nach Zahnriemenwechsel Diesel Engine Technology
No new posts after timing belt replacement, AUY performance loss Diesel Engine Technology
