Diesel & engine technology, repair & maintenance.
Dauerhafte DPF Regeneration nach Zahnriemenwechsel | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Dieselschrauber Bar
huebi
Post19-07-2026, 23:29    Subject: Quote
Marco_mk75 wrote:
I'm just surprised that the pre-catalyst has a temperature of 700 degrees and the post-catalyst has a temperature of 200.
Something isn't right; it can't lose that much temperature on such a short path, less than 500 degrees.
"Without a load, the downstream catalytic converter temperature is significantly lower. However, if you accelerate for a period of time, it will also increase. During DPF regeneration, the downstream catalytic converter can even get hotter because soot is being burned inside the catalytic converter."
Translated on 19-07-2026, 23:30.
Marco_mk75
Post19-07-2026, 23:44    Subject: Quote
Yes, I drove up to 200 km/h. At that speed, the S1 temperature reached 700 degrees, while the S2 temperature remained consistently at 200 degrees.
Translated on 20-07-2026, 19:54.
Karma: +787 / -0   Thank you, like it!
Post20-07-2026, 19:55    Subject: Quote
Marco_mk75 wrote:
Yes, I drove up to 200 km/h, and at that speed, the S1 reached 700 degrees, while S2 remained consistently at 200 degrees.
Okay, that's strange. Does the reading seem accurate when the car is cold?
Translated on 20-07-2026, 19:55.
Marco_mk75
Post20-07-2026, 19:56    Subject: Quote
Yes, it's the same when the car is cold.
Translated on 20-07-2026, 19:56.
No new posts Windshield Wiper Regeneration General Tips
No new posts 1.6l CR-TDI, frequent regeneration / Diesel particulate f... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Regeneration nach km Diesel Engine Technology
No new posts Noise after timing belt replacement Diesel Engine Technology
No new posts Spannrollenproblem nach Zahnriemenwechsel Diesel Engine Technology
No new posts after timing belt replacement, AUY performance loss Diesel Engine Technology
