MAN TGE: Start Tire Change Mode (IDE03331)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
garage_bardill
Post24-08-2026, 10:09    Subject: MAN TGE: Start Tire Change Mode (IDE03331) Quote
Attempting to replace the brake pads on a MAN TGE 2026. Unfortunately, the following error message appears: "Unknown error, cannot start."
Why?
"LG" can be translated as "Best regards" or "Sincerely". It is a common abbreviation for "Liebe Grüße", which means "Warm greetings" in English.
Log-WMA03VUY9T9008203-26891km.txt
 File name:  Log-WMA03VUY9T9008203-26891km.txt
 File size:  19.65 KB
 Downloaded:  5 times
Translated on 24-08-2026, 20:06.
Post24-08-2026, 11:31    Subject: MAN TGE: Start Tire Change Mode (IDE03331) Quote
Your vehicle uses SFD+SFD2, see:
https://shop.dieselschrauber.org/en/sfd-checker.php
I'm looking into what can be done.
Basis:
Enabling the Vehicle Diagnostics Protection (SFD).
While we are working on automating the release process, VCDS already supports the release and lock procedure using offline release tokens.
The following steps are recommended when working on SFD-protected vehicles:
1. Determine which control units you need to work with, for example:
- Brake electronics for work on the parking brake.
· Information electronics for service reset.
2. Check if the diagnostic firewall was disabled when opening the hood. This can be done by connecting to the "Diagnostic Interface for Databus / Gateway" (address 19) and displaying the extended values for the diagnostic filter. Results like the following confirm that you do NOT need to unlock address 19 before making changes in other control units:
· IDE13754-MAS16867 Diagnostic filter: Deactivation reason status → Hood open.
· IDE13754-MAS16875 Diagnostic filter: Status filter status → Filter is not active.
In this case, you can skip steps 3 and 4. The diagnostic firewall is already disabled.
3. If the status is "Filter active," you must request a challenge/token for the "Diagnostic Interface for Databus / Gateway" (address 19) and all additional SFD-protected ECUs that you need to work with. The results would look like this:
· IDE13754-IDE04447 Diagnostic filter: Status-Function status → Function active: SFD protected.
· IDE13754-MAS16875 Diagnostic filter: Status filter status → Filter active.
In this case, you need to follow steps 3 and 4. The diagnostic firewall is enabled.
4. Unlock (SFD) the "Diagnostic Interface for Databus / Gateway" (address 19) and check whether the following value displays a number of minutes that is not zero.
· MAS18157-MAS18164: SFD-enabled status duration for the vehicle diagnostic system to be protected → 89 minutes (this counts down to zero; after that, SFD is automatically re-locked).
5. Disable the diagnostic filter in the "Diagnostic Interface for Databus / Gateway" (address 19) - typically via the adaptation channel IDE16611-diagnostic filter: temporarily change from "active" to "inactive" - and check the following measurement value:
· IDE13754-MAS16866 Diagnostic filter: Distance threshold → 20 km (this counts down from 20 km to zero; after reaching zero, the filter is automatically re-enabled).
6. Unlock (SFD) all additional SFD-protected control units on which you want to work.
 File size:  441.86 KB
 Viewed:  27 times
Translated on 24-08-2026, 11:52.
Post24-08-2026, 20:06    Subject: MAN TGE: Start Tire Change Mode (IDE03331) Quote
VCDS needs to be updated to the latest beta version (it can be installed alongside the current version).
https://www.ross-tech.com/vcds/download/beta/current.php
Post24-08-2026, 20:15    Subject: MAN TGE: Start Tire Change Mode (IDE03331) Quote
SFD registration, see:
https://community.dieselschrauber.org/en/viewtopic.php?t=31009&start=16
I'll see what I can do while Beta and someone else aren't as proficient in English.
1. Access control unit 19 → Perform SFD unlocking → Adjust settings.
"Set the 'Diagnostic_filter_temporary_deactivation' parameter to 'disable'."
2. Access control unit 03 → Perform SFD unlock procedure → Basic settings:
"Execute the 'Start tire change mode' function."
3. Perform mechanical work.
4. Then, control unit 03 → Basic settings:
"Execute "IDE03330 - Exit tire change mode"."
5. The system may need to be calibrated. Afterwards, restore the default settings.
"Execute the
"IDE05335-ENG114972 – Functional test of electromechanical parking brake – Routine Control Option"."
Translated on 24-08-2026, 20:18.
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kat Regenerierung starten mit VAG COM On-Board Diagnostics (OBD)
No new posts a6 avant v6 tdi, bj. 6/98 beim starten morgens auf nur 4 zyl Diesel Engine Technology
This topic is locked, you cannot edit or reply. Beim starten blickt OEL im Tacho auf?!??! Diesel Engine Technology
No new posts Golf 4 starten nicht immer On-Board Diagnostics (OBD)
