AdBlue Countdown: No Error Messages
dominik_77
dieselschrauber likes this.
Post27-08-2026, 11:01    Subject: AdBlue Countdown: No Error Messages Quote
Hello everyone,
Please excuse us if this topic has already been discussed. We have read the relevant threads, but have not found a solution to our problem. Furthermore, we are facing a time-sensitive issue.
We are in Mongolia with our VW T6, model year 2016, and we have a "Ad Blue (DEF) countdown" warning (engine will not start after 1000km). We need to be at the Chinese border on September 1st, so we would be very grateful for your help.
We had the error codes P204F and P20EE, along with a countdown timer related to AdBlue. We were able to clear these errors using a simple OBD scanner and the CarScanner app, and they haven't reappeared.
We have to mention that we already experienced the countdown, including error messages, approximately 8,000 km ago. However, these issues disappeared after a longer period of consistent driving.
- The DPF regeneration is functioning correctly.
- AdBlue is filled (70%) - we can't say much about the quality - it may not be perfect (it comes from Kazakhstan and a little from Mongolia, and we had it filled by a workshop after the problem occurred).
- We removed and cleaned the AdBlue injector. It was slightly dirty.
We have a VCDS here since today, and we have already done the following:
- Autoscan performed.
- AGR check passed - OK.
- IDE00471: DPF regeneration service performed and completed.
We wanted to test the efficiency of the SCR, but it's not triggering, and the incandescent lamp isn't lighting up. What could be the reason for this?
We performed the auto-scan and have attached the results.
Maybe you have some more ideas about what we can do. We're feeling quite desperate right now.
Thank you in advance, and best regards.
Dominik.
Log-WV1ZZZ7HZHH069165-154310km.txt
 File name:  Log-WV1ZZZ7HZHH069165-154310km.txt
 File size:  15.49 KB
 Downloaded:  7 times
Translated on 27-08-2026, 11:05.
Post27-08-2026, 19:36    Subject: AdBlue Countdown: No Error Messages Quote
Are the temperature readings for the DPF plausible? Is the DPF regeneration function working?
The NOx sensor might also be faulty. Is the ECU software up to date?
Translated on 27-08-2026, 19:37.
Karma: +1333 / -0   Thank you, like it!
Post28-08-2026, 6:08    Subject: AdBlue Countdown: No Error Messages Quote
I've noticed that at a mileage of 154,171 (approximately 130 km before the recording), errors are stored in four control units, with some of the date entries being nonsensical. Three of these relate to communication problems between the control units. Consequently, the main control unit (MSG) is not reporting "ready." This indicates a wiring problem.
It may not be related to the AdBlue issue, but it could be.
First, check the connection between the generator and the vehicle's electrical system.
Regarding error codes P204F and P20EE, one can find quite a bit of information on the internet, including https://autodiagnostic-richter.help/fehlercode-p20ee-p204f..
And most importantly, make sure to completely fill the AdBlue tank, otherwise the counter won't reset.
Translated on 28-08-2026, 6:10.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A6 4B, Türschloß ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Verbrauch Touran 1.9 TDI mit / ohne Blue Motion Diesel Engine Technology
No new posts Error messages due to incorrect cable connector connections Diesel Engine Technology
No new posts VCDS Error Codes related to Dynamic LWR 0003 On-Board Diagnostics (OBD)
No new posts VAG-COM 306.0 error messages regarding. TDI Timing / VAG-... Diesel Engine Technology
