Calibrating the intake manifold pressure sensor on a 1.4 TSI engine
harzer1
Post30-01-2024, 15:55    Subject: Calibrating the intake manifold pressure sensor on a 1.4 TSI engine Quote
Hello, I replaced the potentiometer for the intake manifold flaps on my Golf 5, 1.4 TSI, BLG engine.
ERWIN VW states that after the replacement, the learned values should be erased and the engine control unit should be reprogrammed.
Is this path available in VCDS as well?
Post30-01-2024, 17:05    Subject: Calibrating the intake manifold pressure sensor on a 1.4 TSI engine Quote
Autoscan is missing... I would say, based on my gut feeling, that the adaptation channels from the engine control unit should be checked.
MihaiMM
dieselschrauber and guste100 likes this.
Post09-10-2026, 21:04    Subject: Golf 5 1.4 TSI BLG Quote
On the Golf 5 1.4 TSI BLG, the intake manifold flap potentiometer is G336.
After replacing it, the learned values need to be reset and the intake manifold flap system adapted.
VCDS may be able to perform this through 01-Engine → Basic Settings, depending on the ECU software version.
However, VCDS cannot flash or reprogram the ECU firmware. If Erwin (siehe Fehlerdatenbank) specifically requires a software update, ODIS or another compatible programming tool is needed.
Could you post the ECU part number and software version from your VCDS Auto-Scan? That would help identify the correct adaptation procedure.
MM
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Key Programming: Can it work with A8? On-Board Diagnostics (OBD)
No new posts Audi A8 4E: Program new keys On-Board Diagnostics (OBD)
No new posts ESP comparison > Poti and... HDK Sensors Diesel Engine Technology
No new posts MKB 1Z Error Codes: Slider Position Potentiometer - G99 Diesel Engine Technology
