Access Control: Steering for Default Settings
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
improved.ch
Post13-11-2026, 13:44    Subject: Access Control: Steering for Default Settings Quote
Good day.
Attached is a Screenshot of the problem: there is no code available to set the active steering to the default setting (after replacing the centering ring).
Thank you very much for your help and efforts!
Error memory:
VCDS
The Windows-based VAG/VAS emulator runs on Windows 11 x64.
Version: RKS 26.9.0
http://shop.dieselschrauber.org/en
Dealer/Workshop name:
Company number: 000 00000
Self-diagnosis protocol.
Friday, November 13, 2026, 10:38:48:36458
Vehicle Identification Number (VIN): WUAZZZF49JA90xxxx
License plate: xxxxxxxx
Mileage: Repair order: 11/26/2023.
Control unit part number: 8W0 907 144 J, HW: 8W0 907 144 C.
Component and/or version: SCU_MLBevo H03 0710.
Encoding:
Company number:
ASAM Dataset: EV_SCUZFLSAU49X 002019 (AU49)
VCID: 42DCBF63F40737BAB14-8016
2 error codes found:
18432 - Control unit for active steering.
C115C 54 [00001001] - No default setting.
confirmed - checked since last deletion.
Environmental conditions:
Error priority: 4.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:03:55
Extended environment data: Error type 10 - 00 01.
Extended environmental data: Supply voltage at terminal 30: 11.70 V.
Extended environment data: 10-degree steering angle: internal value: 0°.
Extended environmental data: 10-motor current: 0.70 A.
Extended environment data: 10-System status: Engine off.
Extended environment data 10: Calculated vehicle speed: -140 km/h.
Extended environment data: 10-Active_steering_internal_status: Initializing.
Extended environment data: 10-position_control_mode: NormalPositionControl.
Extended environment data: 10-degree steering wheel angular velocity: 0 °/s.
Extended environment data: 10-Steering_torque_eps: 0.00 Nm.
19968 - Steering angle sensor.
B1168 54 [00001000] - no default setting.
Sporadically - confirmed - checked since last deletion.
Error priority: 5.
Error frequency: 1.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 10:20:22
VCDS
Control unit part number: 8W0 907 144 J.
Page 2.
Extended environment data: Error type 10 - 00 00.
Extended environmental data: Supply voltage at terminal 30: 14.70 V.
Extended environmental data: 10-motor current: 0.90 A.
Extended environment data: 10-System status: high.
Extended environment data 10-Steering_torque_eps: 0.00 Nm
Autoscan:
VCDS
VCDS Version: RKS 26.9.0 Data version: 20261009 DS378.1
Company number: 000 00000 000000
Friday, November 13, 2026, 10:53:58:36458
Mileage: 117995 km
Repair order:
Vehicle type: F4-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46 47
52 5F 65 69 6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
Vehicle Identification Number: WUAZZZF49JA904164
Mileage: 117995 km
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: Error 0010.
08-Climate Control/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
13-meter distance rule -- Status: Error 0010.
15-Airbag -- Status: Error 0010.
16-Wheel Steering Electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
1B-Active Steering -- Status: Error 0010.
29-Channel lighting control, left side -- Status: OK 0000
32-bit memory electronics -- Status: Error 0010.
36-seat adjustable passenger seat -- Status: OK 0000.
39-Light control, right side -- Status: OK 0000
3C Lane Change -- Status: Error 0010.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: Error 0010.
46-Comfort System -- Status: Error 0010.
47-Sound System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
Tire pressure -- Status: OK.
69 followers -- Status: OK 0000
6C Rear-view camera -- Status: Error 0010.
6D tailgate -- Status: OK 0000
74-Chassis tax. -- Status: Error 0010.
81-Selector lever -- Status: OK 0000
82-Head-Up Display (HUD) -- Status: OK 0000
8B Distance Rule 2 -- Status: Error 0010.
A5 Front/Forward-facing camera -- Status: Error 0010.
A9 body sound actuator -- Status: OK 0000
Rear left door electronics -- Status: OK 0000.
Rear right door electronics - Status: OK 0000.
CA sunroof electronics -- Status: OK 0000
CF Track Change Assistant 2 -- Status: Error 0010.
D6-Left lighting control 2 -- Status: OK 0000
D7-Light control, right side, 2 -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
VCDS
Page 2.
License plate number: SG427944
Address 01: Engine Control Module (J623-DECA) Label file: .06M-907-309-V1.clb
Part number SW: 8W0 907 551, Part number HW: 06M 907 309.
Component: V6 2.9l TFSI H11 0008
Revision: B9H11000 CVN: 99DB7EBE
Encoding: 122A003225760D0B34380000000000000000000000000000
Operating number: WSC 12345 123 12345
ASAM Dataset: EV_ECM29TFS0118W0907551 001010
ROD: EV_ECM29TFS0118W0907551.rod
VCID: 7AAC0783DC57BF7AA94-802E
VINID: 9E546AAAA58425A44900404610EEC9F72C
"One error found:"
34193 - Control unit for ESP (Electronic Stability Program).
U0416 00 [00100111] - implausible signal.
unconfirmed - checked since last deletion.
Error priority: 2.
Error frequency: 1.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:02:32
Motor speed: 0.00 rpm.
Normalized load value: 0.0%.
Vehicle speed: 0 km/h.
Coolant temperature: 38 °C.
Intake air temperature: 26 °C.
Atmospheric pressure: 940 millibars.
Voltage at terminal 30: 11,660 V.
Lost learning cycles via OBD: 40.
Powertrain Coordinator: ACC fault status bits 0-7: 0.
Powertrain coordinator: Brake function status bits 0-7: 0.
Powertrain coordinator: Brake function status bits 0-7: 32.
Acceleration: 0.000 m/sÂČ
Readiness: 1110 0000
Address 02: Transmission (J217) Label file: | DRV\0BK-927-156.clb
Part number SW: 8W0 927 158 K, hardware number: 0D5 927 156 H.
Component: 0D5 29TSIRdW H05 1003
Revision: --H05--- CVN: 0AD6CA30
Encoding: 100000
Operating number: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX52011 002013
ROD: EV_TCMALX52011.rod
VCID: 4ACC9743CC37EFFA794-801E
No error codes found.
VCDS
Page 3.
Address 03: Brake electronics (J104)
Label file: DRV\8W0-907-379-V1.clb
Part number SW: 8W0 907 379 AA, Hardware: 8W0 907 379 AA.
Component: ESP9 Premium H13 0200
CVN: ACAD0D7A
Encoding: 50AA6C9930A2AA9A519F4897428118A2E6A5DA0A360C558A1242184567A55B
Operating number: WSC 06324 790 00001.
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 0450797BAE93F98AC38-8050
"One error found:"
12851462 - Control unit for active steering.
U0419 00 [10101111] - implausible signal.
[Plausibility check of signals in PDU SCU 01]
Warning light ON - confirmed - checked since last reset.
Error priority: 3.
Error frequency: 1.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:32
71 00 82 00 C2 00 00 00 00 00
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 08: Climate Control/Heating Module (E87) Label file: * None.
Part number SW: 8W0 820 043 T, Hardware: 8W0 820 043 T.
Component: Climate Zone 3 H60 0251.
Encoding: 2608080D5549010D020201008B0000000000000000000000000000000000
Operating number: WSC 06335 790 00001.
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D0B97BEE13398A838-8010
Control unit for the fresh air blower (front).
Subsystem 1 - Part number SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002582860
Humidity sensor: external.
Subsystem 2 - Part number SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: B1E0983900PAG0MUFU02.
Rear climate control panel:
Subsystem 3 - Part number SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: E265 Kli Fond H40 0080
VCDS
Page 4.
Address 09: Central Electronics (J519) Label file: * Diversion failed!
Part number SW: 8W0 907 063 CG, Hardware: 8W0 907 063 BG.
Component: BCM1 MLBevo H13 0267
Data status number: 8W0909514L 0048.
Encoding: 07501943C13900CD050D511998BF9CF9130B3D040000000000000000600016810A4502ABA2B70A
Operating number: WSC 06325 790 00001.
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 025C7F63B487F7BAF14-8056
Wiper motor control unit:
Subsystem 1 - Part number SW: 8W1 955 119 HW: 8V1 955 119 A Label file: DRV\1KX-955-119.CLB
Component: WWS491 180526 043 0813
Serial number: 89435300301814600155.
Encoding: 5BC7F7
Rain and light sensor:
Subsystem 2 - Part number SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21584991X81A955555A0
Encoding: 0200FF
Light switch:
Subsystem 3 - Part number SW: 4M0 941 531 AH HW: 4M0 941 531 AH
Component: E1 - LDS H06 0008
Serial number: 18 04 2018 01407024
Control unit for garage door opener:
Subsystem 4 - Part number SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z00TZ02
Encoding: 310000
Subsystem 5 - Part number SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180616145741 00782.
Automatically dimming interior rearview mirror:
Subsystem 6 - Part number SW: 8W0 857 511 HW: 8W0 857 511
Part: Y7_Interior Mirror H09 0002
Serial number: GX1CE127041823810876.
Encoding: 030000
Interior light module:
Subsystem 7 - Part number SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Roof Tile H14 0130
Serial number: B00870812.
Control unit for driving and comfort functions:
Subsystem 8 - Part number SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H17 0010
VCDS
Page 5.
Serial number: 2818000068050002
Encoding: 000000
Ventil block 1, located in the front seat, driver's side:
Subsystem 9 - Part number SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0036
Serial number: 7008174235B182358551.
Encoding: BF0500
Ventil block 1, front seat, passenger side:
Subsystem 10 - Part number SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0036
Serial number: 7008174235B182357969.
Coding: B30500
3 error codes found:
131945 - Data bus: Received error value.
U1123 00 [00001001] - -
[EPS control module: received error value in signal EPS_steering-rack_pos]
Error priority: 6.
Error frequency: 5.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:32
average_Voltage_terminals: 11.20 V
Temperature sensor for outdoor temperature, resistance value: 0.00 kOhms.
Outdoor temperature sensor for ambient temperature via CAN: 16.00 °C.
interior_temperature: 16.50 °C
Vehicle speed: 0.00 km/h.
Terminal status: Terminal 75: on.
Terminal control status: Terminal 15, signal: on.
Terminal control - Terminal 15 via CAN: one.
Terminal control - Terminal 75: Status: off.
196758 - Data bus received error value.
[Brake control module: received error value in ESP system status signal]
Error priority: 6.
Error frequency: 4.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:32
average_Voltage_terminals: 11.30 V
VCDS
Page 6.
196761 - Data bus: Received error value.
[Power steering control module: received error value in the EPS steering rack position signal.]
Error priority: 6.
Error frequency: 4.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:32
VCDS
Page 7.
Address 13: Distance Control (J428) Label file: * Bypass due to failure!
Part number SW: 8W0 907 561 C, hardware number: 8W0 907 561.
Component: LRR4 H10 0340
Data record number: 8W0909863J 0003.
Encoding: 3477FFFB58FFEC06757A61A0
Operating number: WSC 99999 999 2097151.
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 3E24CB9380FF535AD5C-806A
8 error codes found:
2179 - Data bus: implausible message.
U1122 00 [00001000] - -
[FAULT_EPS_ESS_REQ_NOT_POSSIBLE_HIGH_POWER_FAIL]
Error priority: 6.
Error frequency: 2.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 09:00:35
Engine control unit temperature: 27 °C.
Voltage at terminal 15: 10.7 V.
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/sÂČ
Adaptive Cruise Control: Status: ACC_reversible_error.
2106 - Data bus: implausible message.
[FAULT_EPS_REQ_NOT_POSSIBLE_FAIL]
Error priority: 6.
Error frequency: 2.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 09:00:35
Voltage at terminal 15: 10.8 V.
0852 - Data bus: Received error value.
[FAULT_EPS_RACK_POSITION_ERROR]
VCDS
Page 8.
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Voltage at terminal 15: 11.3 V.
2101 - Data bus: Received error value.
[FAULT_ESP_STATUS_SYSTEM]
Error priority: 4.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
2153 - Data bus: Received error value.
[FAULT_HC_STA_FAIL]
Error priority: 4.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
2115 - Data bus: Received error value.
[FAULT_HMS_FAILURESTATE]
VCDS
Page 9.
Error priority: 4.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
1392 - Data bus: implausible message.
U1122 00 [00001001] - -
[FAULT_LRRS_SELFDIAG]
Error priority: 6.
Error frequency: 5.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
0800 - Data bus received error value.
[FAULT_SWA_RELEVANT_ERROR]
Error priority: 4.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
VCDS
Page 10.
VCDS
Page 11.
Address 15: Airbag (J234)
Label file: | DRV\8W0-959-655-V1.clb
Part number SW: 8W0 959 655 H, Hardware number: 8W0 959 655 H.
Component: Airbag
10.44 H04 0107
Serial number: 003UR000HTM% Data version number: 8W0909602AH 0007
Encoding: AAFCF0C000800000985400F3D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4EC49B53305FC3DA25C-801A
Seat belt pretensioner, left side:
Subsystem 1 - Part number SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W0857705F0179S00100
Encoding: 88001B
Right-side seatbelt pretensioner:
Subsystem 2 - Part number SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W0857706G0179S00171.
Encoding: 88001B
Crash sensor for driver-side side airbag:
Subsystem 3 - Part number: SW: ----------- HW: 442 060 607 18
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00AF27DBDE2446S
Encoding: 2D2D2D
Crash sensor for the side airbag, passenger side:
Subsystem 4 - Part number: SW: ----------- HW: 442 060 707 18
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00A727578D47378
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side).
Subsystem 5 - Part number: SW: ----------- HW: 442 0B3 006 18
Part number: SideSensor_Dr 1C7 0148
Serial number: 3517700AD2A7757412CH
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 6 - Part number: SW: ----------- HW: 442 0B3 006 18
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700AF2B0ECB5A09.
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 7 - Part number: SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B52A9BC71421E.
Encoding: 2D2D2D
VCDS
Page 12.
Crash sensor for front airbag, passenger side:
Subsystem 8 - Part number: SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B92A9BC74643S.
Encoding: 2D2D2D
6 error codes found:
9682162 - Multi-collision brake.
B13BC F2 [10001001] - No function.
Error priority: 2.
Error frequency: 2.
Lost count: 11.
Mileage: 117,992 km
Date: 2026.11.12
Time: 14:36:07
1061893 - Data bus received error value.
[NWD: 0x0A0 LH_EPS_04 error value EPS_Rack_Position]
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:03:20
1060613 - Data bus: Received error value.
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Object status]
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:03:20
1060614 - Received data bus error value.
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
VCDS
Page 13.
Time: 10:03:20
1060615 - Data bus: Received error value.
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:03:20
1060617 - Data bus: Received error value.
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:03:20
Address 16: Steering wheel electronics (J527)
Label file: DRV\4M0-907-129.clb
Part number SW: 4N0 907 129 PN HW: 4N0 907 129 PN
Component: Steering module H03 0011.
ASAM Dataset: EV_SMLSKLOAU736 007012
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: 0C40515B86C3B1CA8B8-8058
Address 17: Circuit breaker module (J285)
Label file: * Bypass due to failure! - SRI2
Part number SW: 8W5 920 790 D, Hardware number: 8W5 920 790 D.
Component: FBenRDW H19 0377
Encoding: 050D79CE7CB8000800B3FD641000601000000000
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU49.rod
VCID: 43D2BA67EB1D3EB2BA2-8016
VCDS
Page 14.
Address 19: Diagnostic interface (J533)
Label file: * None
Part number SW: 8W7 907 468 F, hardware number: 8W7 907 468 E.
Component: Gateway H42 0123.
Revision: 7C000001
Serial number: 0187C591318707
Data status number: 8W0909515J 0059
Encoding: 03010001004006405407000000590012FC98000792000000017D078E100000000
GVL: 01587C5808000000C0DCC8000002C800110C00000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180706130811 30935.
Battery monitoring control unit:
Subsystem 2 - Part number SW: 8S0 915 181 C HW: 8S0 915 181 C
Part number: J367-BDM, Hella H10, 9070.
Serial number: 2301428504.
"One error found:"
8519683 - Active energy management.
U140B 00 [00001001] - -
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:13:05
EM_vehicle_state: 00 14
Standby current cutoff level: Cutoff level 1.
Requirement: Standby heater activation prohibited. Standby heater: Allowed.
Requirement: Stand heater activation disabled. Allowed runtime for stand heater: 0 minutes.
VCDS
Page 15.
Address 1B: Active Steering (J792)
Label file: None.
Part number SW: 8W0 907 144 J, hardware number: 8W0 907 144 C.
Component: SCU_MLBevo H03 0710
Serial number: 30303030303030
Data version number: 8W0909848P 0002
ROD: EV_SCUZFLSAU49X_002.rod
Error priority: 4.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:03:55
Error priority: 5.
Error frequency: 1.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 10:20:22
VCDS
Page 16.
Address 29: Left-hand light control (J1018). Label file: 4M0-907-397.clb.
Part number SW: 4M0 907 397 AD, Part number HW: 4M0 907 397 D.
Component: LCM_MLBevoH05 0024
Data status number: 8W0909519B 0010.
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_AU37.rod
VCID: 79AE188FD951B462A0E-802C
VCDS
Page 17.
Address 32: Keyless entry electronics (J187)
Label file: DRV\8W0-907-163.clb
Part number SW: 8W0 907 163, Part number HW: 8W0 907 163.
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605826515200107
Encoding: 0003
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
"One error found:"
33263 - Data bus: Received error value.
U1123 00 [00001000] - -
Error priority: 6.
Error frequency: 3.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 09:57:37
Active Backup Function: TEMPORARY SHUTDOWN 20
Status of QSP: Temporarily Shut Down.
Program Counter: 00 00 00 00
Reset Fault Code: SCM_E_NONE
Number of resets: 0
Active fault: SCM_E_NONE
Active extended fault: SCM_E_EXTENT_NONE.
SCM_E_PFM_NOK: inactive.
SCM_E_ASIL_RAM_PROT: inactive.
SCM_E_ASIL_RAM_DEFECT: inactive.
SCM_E_ASIL_ROM: inactive.
SCM_E_MC_SUPPLIES: inactive.
SCM_E_HW_TSBC_RST_UNLIMITED: inactive.
SCM_E_MPT_AUDI: inactive.
SCM_E_BSW: inactive.
SCM_E_TRAP_X2: inactive.
SCM_E_TRAP_X3: inactive.
SCM_E_TRAP_NMI: inactive.
SCM_E_TRAP_ECC_FLASH: inactive.
SCM_E_TRAP_UNKNOWN: inactive.
SCM_E_PCP: inactive.
SCM_E_HW_MU_RST: inactive.
SCM_E_OS_TASK_NOK: inactive.
SCM_E_HW_BIST: inactive.
SCM_E_HW_MU_CFG: inactive.
SCM_E_HW_MU_INVALID_QUESTION: inactive.
SCM_E_HW_MU_WRONG_BEHAVIOR: inactive.
SCM_E_INT_RST: inactive.
SCM_E_HW_TSBC_RST: inactive.
SCM_E_LVL2: inactive.
VCDS
Page 18.
SCM_E_TRAP_X1: inactive.
Reserved: inactive.
SCM_E_SW_RESTART: inactive.
SCM_E_SOPC: inactive.
SCM_E_VSOUTx: inactive.
SCM_E_ADC_REF: inactive.
SCM_E_ADC_STUCK_AT__MULTIPLEX: inactive.
SCM_E_VDD5: inactive.
SCM_E_HW_DEV_ID: inactive.
Occurrence_counter_over_length_of_life: 47
FR_ESP_VL_VR_HL_HR_FR_QBit: 0
Wheel speed, front left: 0.0 km/h.
Wheel speed, front right: 0.0 km/h.
Rear left wheel speed: 0.0 km/h.
Rear right wheel speed: 0.0 km/h.
State EFP: 5
FR_FDR_TV_DesiredTorqueDifference: 0.0 Nm
FR_KBI_Standzeit_02: 3275 s
Transverse acceleration sensor 1: 0.02000 m/sÂČ
Transverse acceleration sensor 1: Status: 0.
Cross-axis acceleration sensor: 0.02000 m/sÂČ.
Transverse acceleration sensor 2: Status: 0.
FR_KBI_Tire circumference: 2068 mm
FR_Motor_Code_01: 2
Address 36: Seat adjustment for driver (J136) Label file: * None.
Part number SW: 4M4 959 760, Part number HW: 4M4 959 760.
Component: MEM-FS 009 0042
Serial number: 00000332438863
Data version number: 8W0909856C 0009
Encoding: 00581B000000B0010000010101010000000000000000000000000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
VCDS
Page 19.
Address 39: Right-hand light control (J1023)
Part number SW: 4M0 907 397 AD, HW: 4M0 907 397 D.
Data status number: 8W0909520B 0010.
ASAM Dataset: EV_LCMRightHELLAAU736 001012
VCDS
Page 20.
Address 3C: Lane Change (J769) Label file: | DRV\4M0-907-566.clb
Part number SW: 4M0 907 566 E, Part number HW: 4M0 907 566
Component: MRR1 Rear H20 0430
Revision: -------- Data status number: 8W0909535C 0020
Encoding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 372ADEB7AFC5621216A-8062
1192224 - Data bus received error value.
[databus error value received - EPS_rack_position]
Error priority: 6.
Error frequency: 4.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Engine control unit temperature: 26 °C.
Voltage at terminal 30: 11.10 V.
Status terminal 15: on.
Voltage at terminal 15: Measurement not available.
1192210 - Data bus received error value.
[databus error value received - ESP_Systemstatus]
Error priority: 6.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
267010 - Data bus: Received error value.
[FAULT_SLAVE]
VCDS
Page 21.
Error priority: 6.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Address 42: Door Electric Driver (J386) Label file: * None.
Part number SW: 4M0 959 793 H, Part number HW: 4M0 959 793 F.
Component: TSG FS 005 0130
Serial number: 0000331104321
Data version number: 8W0909872G 0031
Encoding: 005D8A215E00008000011032
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCDS
Page 22.
Address 44: Steering Assist (J500) Label file: | DRV\8W0-909-144-V1.clb
Part number SW: 8W0 909 144 H, Part number HW: 8W0 909 144 B.
Component: EPS_MLBEVO_ZF H08 0410
Data status number: 8W0909852R 0041.
Encoding: 85888380008080
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
26112 - Data bus: Received error value.
[KFC_SCU_01_SNA]
Error priority: 5.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:02:48
Extended environment data: 1-Motor is running: Engine_not_running.
Extended environment data: Supply voltage 1: 0.00 V.
Extended environmental data 1 - Temperature: -70 °C
Extended environment data 1 - System status: 4.
Extended environmental data 1: 00.
Extended environment data: 1-driving_direction: 0.
Extended environmental data 1-KFA: 0.
Extended environmental data 1-KFC: 102.
Extended environment data 1 - Ready_To_Drive_Bit: 0.
Extended environment data 1 - Start/Stop info: 0.
Extended environment data: 1-Steering_Angle_Calculated: 0 °
Extended environment data: 1-Steering_Angle_Calculated_Sign: 0.
Extended environment data: 1-Steering torque: 0.00 Nm.
Extended environment data: 1-Steering_Torque_Sign: 0.
Extended environment data 15-MsgStateFifo_Byte0: 00 00 00 00
Extended environment data: 15-MsgStateFifo_Byte1: FF FF FF FF.
Extended environment data 15-MsgStateFifo_Byte2: FF FF FF FF
Extended environment data 15-MsgStateFifo_Byte3: FF FF FF FF
Extended environment data: 15-NumOfMsgCntFaults: 00
Extended environment data 15-NumOfMsgCrcFaults_2: 00
Extended environment data 15-NumOfMsgNoFaults_3: 00
Extended environment data 15-NumOfMsgTimoFaults_1: 00
17664 - Error value received on the data bus.
[KFC_ESP_22_SNA]
Error priority: 5.
VCDS
Friday, November 13, 2026, 10:53:59:36458
Page 23.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 10:02:48
Extended environmental data 1-KFC: 69.
Extended environment data 15-MsgStateFifo_Byte1: 00 00 00 00
Extended environment data 15-MsgStateFifo_Byte2: 00 00 00 00
Extended environment data 15-MsgStateFifo_Byte3: 00 00 00 00
27136 - Data bus: Received error value.
[KFC_LWI_01_SNA]
Error priority: 5.
Error frequency: 1.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 10:20:22
Extended environment data: 1-Engine running: Engine_Running_Stable.
Extended environment data 1 - System status: 5.
Extended environmental data 1-KFC: 106.
VCDS
Page 24.
Extended environment data: 1-Steering_Torque_Sign: 1.
VCDS
Page 25.
Address 46: Comfort System (J393) Label file: * None.
Part number SW: 8W0 907 064 EC, hardware number: 8W0 907 064 DC.
Component: BCM2 MLBevo 025 0387
Data status number: 8W0909501J 0052.
Encoding: 013400000FB100606309A0006E00480233004008804F06502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 015E706FB181ECA2E8E-8054
Theft alarm sensor:
Subsystem 1 - Part number SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316.
Serial number: 000000000ZY181540Z8F.
Alarm horn:
Subsystem 2 - Part number SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Siren, DWA 005 0314.
Serial number: 00000000000099327905
Control unit for tailgate opening:
Subsystem 3 - Part number SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12057858
"One error found:"
65896 - Data bus: Missing message.
U1121 00 [00001000] - -
[Climatronic control module: Klima_03: no signal/communication]
Error priority: 6.
Error frequency: 1.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 10:23:27
Supply voltage - Supply voltage at terminal 30: 12.636 V.
Supply voltage - Supply voltage terminal 30 - 2: 12.663 V.
Supply voltage - Supply voltage terminal 30 - 3: 12.636 V.
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active.
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Shutdown level 0.
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active.
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
VCDS
Page 26.
general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 10 00 80
general_additional_freeze_frame-Transport_Mode: not active.
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 47: Soundsystem (J525) Label file: * None.
Part number SW: 8W0 035 465, Hardware number: 8W0 035 465.
Part number: MIB2_amp_P_B9 H11 0420.
Revision: 00000001
Serial number: AUZ8ZAJJA04KNGO
Data status number: 8W0909510F 0018
Encoding: 0194020800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 76B413B3E84FDB1ACDC-8022
Address 52: Door electric, passenger side (J387). Label file: * None.
Part number SW: 4M0 959 792 H, Part number HW: 4M0 959 792 F.
Component: TSG BFS 005 0130
Serial number: 0000331131607
Data version number: 8W0909873G 0031
Encoding: 005D8A215E00008000011030
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCDS
Page 27.
Address 5F: Information selection. I (J794) Label file: * 8W0-035-MIB-HGH2.clb
Part number SW: 8W5 035 035 C, hardware number: 8W5 035 035.
Component: MU-P-LND-EU 034 1329
Serial number: A829G0JB078436
Data version number: 8W0909545VM 0003
Encoding: 019462010000000053111102000A00332F000BE5017001009E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
Storage media:
Subsystem 1 - Part number SW: V03 959 802 TL HW: -----------
Component: ECE 2020/2021 --- 0187
Serial number: --------------------
Display unit 1 for the multimedia system:
Subsystem 2 - Part number SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00121041800820294
Control unit for multimedia system:
Subsystem 3 - Part number SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK126061800040354
Compact Disc Database:
Subsystem 4 - Part number SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 65: Tire pressure (J502)
Label file: 4M0-907-273.clb
Part number SW: 4M0 907 273 B, Hardware number: 4M0 907 273 B.
Component: RDKHUFAU736 H04 0010
Serial number: 30000000021535
Data version number: 8WA909850A 0002
ASAM Dataset: EV_RDKHUFAU736 002007
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 2F3AE6D75795AAD24EA-807A
VCDS
Page 28.
Address 69: Trailer (J345) Label file: | DRV\5Q0-907-383.clb
Part number SW: 4M0 907 383 D, Part number HW: 4M0 907 383 B.
Component: ConWysTrailer H20 0211
Serial number: 0384670490
Encoding: 0100000202001100
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW37.rod
VCID: 3332EAA7BBBD8E322A2-8066
Address 6C: Rear view camera (J928) Label file: * None.
Part number SW: 4M0 907 428 F, Hardware number: 4M0 907 428.
Component: Areaview 2 H13 0318
Serial number: C854607JG067860
Data version number: 8W1909460J 0018
Encoding: 02940201BF0FA10408404004
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
VCID: 3536D4BFB5C99002046-8060
"One error found:"
13705996 - Received error value on the data bus.
[Error: Value monitoring for LH_EPS_04.EPS, rack and pinion position]
Error priority: 6.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Address 6D: Rear door (J605) Label file: | DRV\5Q0-959-107.clb
Part number SW: 4M0 959 107 B, hardware number: 4M0 959 107 A.
Component: HDSG module H13 0166.
Revision: -------- Serial number: 32023266700000 Data status number: 8W0909541C 0016
Encoding: 05F0
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 323CEFA344A7873A214-8066
VCDS
Page 29.
Address 74: Chassis Control. (J775) Label file: * None.
Part number SW: 8W0 907 777 Q, Hardware number: 8W0 907 777 C.
Component: Chassis - Part Number H37 1251.
Serial number: 0607180886
Data version number: 8W0909576M 0001
Encoding: D46048415A
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
VCID: 55F6743F1589B002E46-8000
3407876 - Received error value on the data bus.
[Internal communication error - ESP system status]
Error priority: 6.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Internal error code: 84.
4456458 - ABS control unit.
U0415 00 [00001001] - implausible signal.
[Function_restriction_due_to_communication_interruption_EspOverSteer]
Error priority: 4.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Internal error code: 130.
4456531 - ABS control unit.
[Function restriction due to communication interruption - Esp Understeer]
Error priority: 4.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Internal error code: 138.
VCDS
Page 30.
6553607 - Control unit for active steering.
U0419 00 [10001001] - implausible signal.
[Function_restriction_due_to_communication_interruption_VariableSteeringAngle_AudiDynamicSteering]
Error priority: 4.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Internal error code: 236.
6553608 - Steering angle sensor.
U0428 00 [00001000] - implausible signal.
[Function restriction due to communication interruption: Steering wheel angle sensor value]
Error priority: 4.
Error frequency: 3.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 09:00:45
Internal error code: 237.
6553620 - Control unit for active steering.
[Function restriction due to communication interruption - Total Steering Angle - Audi Dynamic Steering]
Error priority: 4.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Internal error code: 248.
6553633 - ABS control unit.
U0415 00 [10001001] - implausible signal.
[Function_restriction_due_to_communication_interruption_FlagMonitoringSteeringWheelAngleOffset]
Error priority: 4.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
VCDS
Page 31.
Date: 2026.11.13
Time: 08:59:31
Internal error code: 249.
6553637 - ABS control unit.
[Function_restriction_due_to_communication_interruption_OffsetSteeringWheelAngle]
Error priority: 4.
Error frequency: 2.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Internal error code: 253.
Address 81: Selector lever (J587)
Label file: 4MX-713-041-81.clb
Part number SW: 8W1 713 041 M, hardware number: 4M1 713 041 G.
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18060947687233
ASAM Dataset: EV_GSMWaehlZFAU736 001017
FILE: EV_GSMWaehlZFAU736.rod
VCID: 3D26CC9F8DF94842CC6-8068
Address 82: Head-Up Display (HUD) (J898) Label file: | 4M0-919-617-V1.clb
Part number SW: 8W5 919 617 B, Hardware number: 8W5 919 617 B.
Component: Head-Up Display H18 1640.
Encoding: 4F01D0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 47CAAE77DF25129266A-8012
VCDS
Page 32.
Address 8B: Distance regulation 2 (J850)
Label file: 4M0-907-541.clb
Part number SW: 8W0 907 541 C, hardware number: 8W0 907 541.
Data status number: 8W0909885E 0001.
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 3C20C19B96E3414AFB8-8068
"One error found:"
Error priority: 6.
Error frequency: 3.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Engine control unit temperature: 24 °C.
Adaptive Cruise Control: Status: ACC_Off_MainSwitch_Off
VCDS
Page 33.
Address A5: Front/Forefield camera (R242) Label file: *Detour failed!*
Part number SW: 8W0 907 217 C, hardware number: 8W0 907 217 C.
Component: BVS H18 0050
Data status number: 8W0909466F 0035.
Encoding: 0404090200000403012023A7C50000FCB0F0C020E280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
1123714 - Data bus received error value.
[Airbag_01_AB_System Error]
Error priority: 6.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:35
Control unit temperature: 21 °C.
Voltage at terminal 15: 11.30 V.
1123157 - Data bus: Received error value.
[LH_EPS_03_EPS_Calculated_LW]
Error priority: 6.
Error frequency: 4.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
1123159 - Data bus received error value.
[LH_EPS_04_EPS_Rack_and_Pinion_Position]
Error priority: 6.
Error frequency: 4.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
VCDS
Page 34.
1123173 - Data bus received error value.
[ESP_21_ESP_System Status]
Error priority: 6.
Error frequency: 1.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
1123733 - Received error value on the data bus.
[SWA_01_SWA_rel_Error]
Error priority: 6.
Error frequency: 4.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
4195335 - Received error value on the data bus.
[STA_requirement_not_workable]
Error priority: 6.
Error frequency: 2.
Lost Count: 51
Mileage: 117995 km
Date: 2026.11.13
Time: 09:00:36
Control unit temperature: 22 °C.
Voltage at terminal 15: 11.10 V.
VCDS
Page 35.
Address A9: Body sound actuator (J869)
Label file: 4H0-907-159.clb
Part number SW: 8W0 907 159 C, hardware number: 4H0 907 159 A.
Component: SAS-GEN 2 H07 0005
Serial number: 180611200015
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
VCID: 41DEB06FF1012CA2A8E-8014
Address BB: Rear left door electronics (J388) Label file: * 5QX-959-DCR-V2.clb
Part number SW: 4M0 959 795 H, Part number HW: 4M0 959 795 F.
Component: TSG HFS 005 0130
Serial number: 0000331270581
Data version number: 8W0909897G 0031
Encoding: 000D88200000008000001020
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 45D6A47FE5290082946-8010
Address BC: Rear right door electronics (J389) Label file: * 5QX-959-DCR-V2.clb
Component: TSG HBFS 005 0130
Serial number: 0000331273935
Data version number: 8W0909896G 0031
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address CA: Sunroof electronics (J245)
Label file: | 4M0-907-594.clb
Part number SW: 4M0 907 594 G, Part number HW: 4M0 907 594.
Component: SAD_STG_1 014 0005
Data status number: 8W0909469D 0009.
Encoding: 6A8000049202
ASAM Dataset: EV_SunRoofCONTIAU736 006008
ROD: EV_SunRoofCONTIAU736_006_VW37.rod
VCID: 3A2CC7839CD77F7AE94-806E
VCDS
Page 36.
Address CF: Lane Change Assist 2 (J770) Label file: .DRV\4M0-907-566.clb
Part number SW: 4M0 907 590 E, HW: 4M0 907 590.
Revision: --------
Encoding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 3430E9BBBEB3890A338-8060
"One error found:"
Error priority: 6.
Error frequency: 4.
Lost count: 11.
Mileage: 117995 km
Date: 2026.11.13
Time: 08:59:31
Address D6: Left-side lighting control 2 (A31)
Label file: 7PX-941-LED-V1.clb
Part number SW: 7PP 941 571 BC, Part number HW: 7PP 941 571 B.
Component: LED1L H09 0008
Data status number: 8W0909471C 0008.
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 176A3E37CF05421236A-8042
Address D7: Right-hand lighting control 2 (A27)
Component: LED1R H09 0008
Data status number: 8W0909472C 0008.
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
Ende--(Dauer: 03:01, Batt.-Spannung Start/Ende: 11.3V/11.3V. VIgn 11.4V)---
VCDS
Page 37.
--------------------------47 error codes found--------------------------
 File size:  1.59 MB
 Viewed:  176 times
Translated on 13-11-2026, 19:01.
Post13-11-2026, 14:30    Subject: Access Control: Steering for Default Settings Quote
Please try using the codes 40168 or 61378 (Audi).
Translated on 13-11-2026, 14:31.
improved.ch
Post13-11-2026, 16:54    Subject: SEO: No Success? Tips & Strategies Quote
Unfortunately, I was still unsuccessful with that number.
Translated on 13-11-2026, 16:55.
Post13-11-2026, 18:09    Subject: Access Control: Steering for Default Settings Quote
Okay, I've forwarded the issue to Ross-Tech and will let you know what they say.
Translated on 13-11-2026, 18:09.
improved.ch
Post13-11-2026, 18:40    Subject: Access Control: Steering for Default Settings Quote
Thank you very much.
Good evening.
Greetings.
Translated on 13-11-2026, 18:40.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post14-11-2026, 14:22    Subject: Access Control: Steering for Default Settings Quote
The login codes should work. Additionally, there is also the login code 20103 (which is actually intended for the previous version).
For the active steering system, you need the code 61378. The active steering system is missing the basic calibration.
Please also check the error message in the active steering system: Yes, you have an RS 4, but even with the engine off, it can't go backwards at 140 km/h! The error message reads: "Calculated speed -140".
There are various TPI (Technical Product Information) and SVM (Service Vehicle Information) codes available for steering-related issues and updates. After replacing the steering angle sensor, the dynamic steering system often exhibits erratic behavior. If the steering wheel was misaligned by a tooth during the replacement, it can subsequently cause problems with calibration and adjustment.
Please review the relevant TPIs again. It is likely that the problem cannot be resolved without using ODIS.
Was wÀre, wenn der steering angle sensor ausgetauscht wurde, weil verschiedene assistance systems failed beim Starten und Fehlermeldungen wurden im Display angezeigt?
Michael.
Translated on 14-11-2026, 14:24.
Post17-11-2026, 19:51    Subject: Access Control: Steering for Default Settings Quote
I'm sending you a link for testing.
Translated on 17-11-2026, 19:52.
Post21-11-2026, 13:00    Subject: Access Control: Steering for Default Settings Quote
Did it work with the new VCDS version?
"Security Access" is correct?
Translated on 21-11-2026, 13:01.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Access permission, radial dampening On-Board Diagnostics (OBD)
No new posts Electrical Access Control: Configuration & Setup On-Board Diagnostics (OBD)
No new posts ECU Access: BKD Engine Control Unit (EDC16) On-Board Diagnostics (OBD)
No new posts Access Permission: Function 16 Not Selectable On-Board Diagnostics (OBD)
