Joined: 04/12/2002 Posts: 18144 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
22-11-2026, 14:54 Subject: DIY Projects: What are you building? |
Das hier ist kein Thema für fertige Autos und Hochglanz-Vorstellungen. Hier geht's um das, was gerade auf der Bühne, im Carport oder auf dem Hof steht, auch wenn es noch zerlegt ist. GRight then.
Just write:
- What is it? A car, a scooter, a lawnmower, it doesn't matter.
- What are you working on right now?
- What's running, what's stuck, and what's still missing?
- Photo of the current condition. A phone picture is sufficient; workshop messiness is explicitly allowed.
"Oil change and a beer."
And if you see something from someone that interests you, a thumbs-up or a sentence is enough. No one is obligated to provide a professional response here, but they can if they choose.
So, what's on your mind right now?
Translated on 22-11-2026, 14:55.
Profile PM WWW Garage |
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2560 Karma: +595 / -0 Location: bei Zwickau
dieselschrauber and Hutfahrer likes this. |
22-11-2026, 18:45 Subject: DIY Projects: What are you building? |
Currently, everything is running smoothly for me: cars, motorcycles, lawnmowers, and tractors.
The last thing I did was work on the motor of my electric bicycle.
There's a stupid connector in there, a type used in compact plugs.
"There are always problems with this. It's a known issue; somehow, unsuitable materials are being used that are incompatible with each other. They may even be releasing chemicals that exacerbate the problem. You can see in the picture that the pins are discolored black, specifically in the contact area."
After disassembling the motor four times and cleaning the contacts,
I've bridged all of that now.
Okay, let's see if the motor works reliably now. Otherwise, I'm completely satisfied with it.
| Description: |
| File size: |
1.14 MB |
| Viewed: |
166 times |
| Description: |
| File size: |
227.08 KB |
| Viewed: |
170 times |
Translated on 22-11-2026, 21:33.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1514 Karma: +649 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
dieselschrauber and huebi likes this. |
24-11-2026, 5:11 Subject: DIY Projects: What are you building? |
"I bought an A6 4f Allroad 3.0 TDI, knowing that the DPF and AGR systems had been reprogrammed... The seller "forgot" to tell me that there was an ongoing recall related to the Dieselgate scandal... I managed to get a significant refund, but now I have to deal with this whole situation."
Translated on 24-11-2026, 9:38.
Profile PM Garage |
olli and Herbert likes this. |
24-11-2026, 16:54 Subject: DIY Projects: What are you building? |
Repainted 8-year-old VW T6 rims with winter tires. They now look brand new!
| Description: |
| File size: |
2.68 MB |
| Viewed: |
103 times |
Translated on 24-11-2026, 16:55.
Herbert Profi-Schrauber
dieselschrauber likes this. |
25-11-2026, 6:31 Subject: DIY Projects: What are you building? |
I'm getting annoyed (as usual, every year) with how long it takes for the engine to warm up. It doesn't reach its proper operating temperature when driving on rural roads unless the temperature is above 5°C. It's not the thermostat; I already replaced it a long time ago, along with the leaky water pump. The old thermostat was also fine when I tested it. It seems to be a characteristic of the engine/cooling system.
Translated on 25-11-2026, 6:32.
25-11-2026, 19:09 Subject: DIY Projects: What are you building? |
Well, it really should.
Okay, so I have an older Golf 4 TDI and a T4 with the ACV engine.
From my own experience: the T4 takes a little longer to warm up.
But even when I'm cycling to work, which is only 6 km and consists of village roads, it gets warm by the time I arrive at my workplace.
"When I drive on the highway for longer distances, let's say over 10 km, it reaches its operating temperature, even if it's, let's say, 5° below zero. So, according to the display and the feeling that the heating is working properly."
Translated on 25-11-2026, 19:10.
Turbinchen Profi-Schrauber
Joined: 04/10/2008 Posts: 201 Karma: +76 / -0 Location: 95615 Marktredwitz 2014 Audi A4 Avant Support
25-11-2026, 21:27 Subject: DIY Projects: What are you building? |
Herbert wrote: | I'm getting annoyed (as I do every year) with the engine taking far too long to warm up. It doesn't reach a real operating temperature when driving on country roads if it's below 5°C. It's not the thermostat; I already replaced it a long time ago, along with the leaky water pump. The old thermostat was also fine when I tested it. It seems to be a characteristic of the engine/cooling system.
Herbert | .
Do you mean the CJCD? I have the same vehicle, and it never really gets warm in the winter. The timing belt and water pump were replaced in the summer, and the thermostat, including the hose thermostat, was also replaced at some point, but it hasn't helped. I suspect it might be related to the water-cooled transmission.
Translated on 25-11-2026, 21:28.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2407 Karma: +442 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
27-11-2026, 10:12 Subject: DIY Projects: What are you building? |
Our 2012 Sharan 7N with the CFGB engine (2.0 TDI with 170 hp) had two thermostats: one for the engine and another in the hose leading to the DSG transmission. The thermostat for the DSG was located under the battery in the car and was defective. Since replacing it, the Sharan heats up comfortably again on country roads. (Before that, even with a diesel auxiliary heater, it couldn't seem to warm up properly).
It's still not a miracle when it comes to heating. In the city, the auxiliary heater still has to work hard, and even in sub-zero temperatures, it's still not reaching a stable 90°C. It's a blessing and a curse, this efficiency.
Translated on 27-11-2026, 10:14.
Profile PM Garage |
