Hi, a little off-topic.
For my T4, I'm planning a few modifications for the spring. I'm thinking of getting new Bilstein shock absorbers, adjusting the torsion bar at the front, installing sport springs with a -20mm drop at the rear, and adding larger stabilizer bars at the front and rear. Since the large TDI puts quite a bit of stress on the wheels, I want to get bigger ones. Instead of 225/60R16 on 7Jx16, I'm considering 235/55R17 or 18 on 8Jx17/18.
Okay, theoretically, all Audi bolt circle patterns 5x110 (?) should fit. But where can I find the load capacities? Will the ones from the A8 be sufficient? The T4 has a front axle load of 1200kg. However, the 3.3 TDI and the W12 also have this load capacity.
Translated on 03-09-2026, 15:07.
