Chip Golf 3
sascha
Post25-06-2002, 19:10    Subject: Chip Golf 3 Quote
I bought a used chip (from Kerscher), and I didn't compare the engine control unit number icon_sad.gif.
The chips are intended for use in control units with the last three digits being 171.
My numbers are 0281 001 308/309 and 028 906 021.
And I don't know if they will work for me.
Can anything break?
Are the control units identical?
Translated on 22-07-2026, 11:46.
Rudi
Post25-06-2002, 22:18    Subject: Chip Golf 3 Quote
Hello Sascha,
'I haven't experienced any ECU failures during EPROM replacements yet, but I'm now certain that there are multiple hardware revisions of the 8-bit ECUs, specifically the MSA12 type, that are not compatible with each other.'
The chip you purchased is designed for a 90 horsepower Golf with engine control unit (ECU) number 028906021C. Your ECU is a 028906021AF (used from 10/1994 onwards).
You can insert the chips, but I don't think anything will happen.
Translated on 22-07-2026, 11:48.
zeka
Post25-06-2002, 22:42    Subject: Chip from Kerscher Quote
hello
The problem is the turbo pressure sensor.
There is a 250 kPa sensor installed in your control unit.
The other control unit only has a 200 kPa sensor.
Plainly put: one version goes up to a boost pressure of 1.5 bar.
The other one only goes up to 1 bar.
I believe your control unit has an immobilizer.
In addition, the integrated circuits are soldered in place, which wasn't the case with the older version.
'Without a soldering iron, you won't be able to test them like this.'
If you have the necessary resources, I might be able to provide you with the files for your car (programming of microchips).
[email protected]
'cu Thomas' translates to 'see you, Thomas' or 'goodbye, Thomas'. It is a casual way of saying goodbye in German.
Translated on 22-07-2026, 11:50.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts WFS Golf3 TDI 1Z Diesel Engine Technology
No new posts Automatic Transmission Volkswagen Golf 3 Transmission, Chassis, Body & Interior
No new posts Schlüsselnummern für Golf3 AFN Mj 97 Diesel Engine Technology
No new posts MFA im Golf3 Tdi nachrüsten Transmission, Chassis, Body & Interior
