Wet Car Interior: Causes & Solutions
Golfdriver
Post06-12-2003, 17:38    Subject: Wet Car Interior: Causes & Solutions Quote
'For the past few days, I've been having a problem where the floor on the driver's side, both in the front and back, is completely wet, almost soaked! It's starting to smell weird, and putting newspapers on it doesn't really help.'
What could be the cause? Could there be a leak somewhere, or is water getting in?
Could it be that this is happening because of something in the ground, perhaps through a hole?
Has anyone ever experienced this problem before, and what's the best way to track down the cause?
(Volkswagen Golf 3 Variant TDI, manufactured in August 1995).
Sure, no problem! Just provide the text you want me to translate.
Hello.
Translated on 14-09-2026, 21:39.
Andy
Post06-12-2003, 18:09    Subject: Wet Car Interior: Causes & Solutions Quote
I would say it's a standard problem icon_smile.gif.
Check if there's any moisture on the underside of the door panel. If there is, you can disassemble the door and either re-glue or replace the seal.
The entire process can also be easily checked by having a second person hold a garden hose against the side window, while someone sits inside and observes where the water is leaking in. icon_evil.gif
Best, Andy.
Translated on 14-09-2026, 21:40.
Gremlin
Post06-12-2003, 18:14    Subject: Wet Car Interior: Causes & Solutions Quote
Does the truck have a sunroof?
CU Gremlin.
Translated on 14-09-2026, 21:41.
Golfdriver
Post06-12-2003, 18:21    Subject: Wet Car Interior: Causes & Solutions Quote
Definitely no sunroof.
Albrecht
Post06-12-2003, 19:13    Subject: Wet Car Interior: Causes & Solutions Quote
In my case, the problem was caused by the door seals, which had been damaged by unprofessional speaker installation, allowing water to enter in the most unexpected ways.
The best approach, as mentioned above, is to spray the car with a garden hose while someone is looking inside. Removing the rocker panel trim beforehand is very helpful.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 14-09-2026, 21:42.
gtdpower
Post22-12-2003, 13:02    Subject: Wet Car Interior: Causes & Solutions Quote
'I also had a water leak in my Golf 3. In my case, it was the sealing ring that seals the cable for the hood. It was a very small hole, almost invisible.'
Nico.
Translated on 14-09-2026, 21:43.
No new posts Exhaust fumes inside the cabin, VW T6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dry the interior General Tips
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aquarium Filter: Galaxy Interior Wet Filter Transmission, Chassis, Body & Interior
No new posts Water leak? Wet seatbelt Transmission, Chassis, Body & Interior
No new posts TDI PD Passat 3BG: 96kW Performance & Acceleration Diesel Engine Technology
No new posts DPF Full: Causes, Repair & Solutions Diesel Engine Technology
