Fehlersuche Climatronic | Posts 16+
Go to page: Previous  1, 2
Andy
Post20-06-2003, 16:26    Subject: Quote
Hello Peter,
The fan located behind the radiator is controlled by the coolant fan control unit J293. The switch states of pressure sensor F129 are evaluated by both the Climatronic control unit and the radiator fan control unit.
Whether the control units for the Golf IV and Passat 3B are identical should be determinable by checking the part numbers.
How familiar are you with using a multimeter?
Can you rule out excessive contamination on the condenser?
Andy.
Julian
Post20-06-2003, 16:52    Subject: Quote
'Could it be that the fuse for the second stage is defective? On a Golf 4, it's a fuse located on the battery.' Let's test it!
Andy
Post20-06-2003, 17:29    Subject: Quote
Okay, so if the fuse is blown, then when you short-circuit the pressure switch, the radiator fan wouldn't go into the second speed setting. That's how he does it, as far as I understand.
Best regards, Andy.
Perly
Post20-06-2003, 18:07    Subject: Quote
@Andy & Julian,
I'll still check the fuse, just in case.
The capacitor looks okay as far as I can tell; I've also tried cleaning it.
I can handle a multimeter:).
Greetings.
Peter.
Post24-06-2003, 13:30    Subject: Quote
@Perly:
Have you taken a close look at the strip fuses? They tend to corrode at the connections, which can lead to intermittent failures. My ABS in my Golf III had the same problem when it got too hot - the fuse strip corroded.
Perly
Post25-06-2003, 17:52    Subject: Quote
@Roger,
Thank you for the tip.
Do you or anyone else know where the fuses are located in a Passat V6 gasoline engine?
There's nothing on the battery.
Thank you.
Peter.
Post25-06-2003, 22:35    Subject: Quote
Have you checked the shock absorber strut housing? On the Golf III, they were located under a small, transparent cover. Otherwise, I would consult the instructions.
Perly
Post06-01-2004, 17:34    Subject: Quote
My problem is solved icon_biggrin.gif.
And I would like to share the solution with you.
Thanks to the information from Andy, localizing the error was relatively simple (for me, apparently not for a VW workshop icon_sad.gif).
It turned out that the second stage of the fan was not activated.
I first checked all the connections of the pressure switch. In doing so, I noticed that the connector located near the servo oil reservoir was not properly connected. A pin inside the connector had slightly shifted. This meant that she only had contact when the plug was fully pushed in.
I then figured out with Andy Plan that this connector tongue belongs to the contact of the pressure switch, which activates the second stage. Voilà, the error is fixed icon_smile.gif. For next to nothing.
The last VW dealer then reimbursed me for the pressure sensor icon_smile.gif, but not for the troubleshooting icon_sad.gif.
Everything has been working perfectly since then icon_smile.gif. Even in hot weather icon_smile.gif. (I was so overjoyed with my success that I forgot to inform you, I'm ashamed.... icon_redface.gif.)
Greetings.
Peter.
Andy
Post06-01-2004, 18:34    Subject: Quote
Hi Peter,
Thank you for the feedback.
Best regards, Andy.
No new posts VCDS: Troubleshooting Performance Issues Troubleshooting & Guides
No new posts Troubleshooting manual air conditioning system, Volkswage... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Not Cooling? Troubleshooting Guide. Transmission, Chassis, Body & Interior
No new posts A4 B6 (AVB) Troubleshooting Guide Diesel Engine Technology
No new posts AKE Troubleshooting: Common Errors and Solutions On-Board Diagnostics (OBD)
No new posts TDI VTG/N75 Troubleshooting: Common Issues & Fixes Diesel Engine Technology
