brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
13-01-2004, 11:46 Subject: Tripod Shaft: Universal Joint for Cars |
Hello!
I have read about tripod joints (also referred to in the gear ratio overview) several times. Can someone tell me what they are and what they look like? What are the differences and advantages/disadvantages compared to "normal" constant velocity joints?
Dirk.
Translated on 29-09-2026, 16:05.
m3_bremse Guest
13-01-2004, 12:20 Subject: Tripod Shaft: Universal Joint for Cars |
If I remember correctly, you can't easily replace or modify it, as it's supposedly glued in place and only authorized service centers can do it.
Translated on 29-09-2026, 16:06.
Jürgen Guest
13-01-2004, 16:30 Subject: Tripod Shaft: Universal Joint for Cars |
Ichnehme an du meinst ein Tripoidgelenk. It is located here.
e.g., on the serrated side of each drive shaft on the Passat 3B.
It's possible that it's the same on the G4 as well.
This is a three-star hotel with a needle-bearing.
Roll onto each of the 3 points. This starfish is attached to the...
A gear is press-fitted onto one end of the drive shaft.
'Typically, it's located on the transmission side (I have one of those tripods myself).'
never seen on the wheel side - I only know constant velocity joints there.
'Suspension joints - By the way, Citroën still used some of these in the 1950s.'
(Cross joints are used!) and the 3 rollers run in 3.
corresponding grooves in the outer housing, which fit onto the drive shaft.
'is located and attached to the transmission. The tripods are...'
relativ alte Konstruktion und sind einfach zu erneuern. Sure, here is the translation of the text from German to English:
'At'
For some vehicle types, it is easier to implement a tripoid joint.
and to reassemble if you need to replace the outer CV joint.
wants to change the cuff.
Translated on 29-09-2026, 16:08.
14-01-2004, 12:28 Subject: Tripod Shaft: Universal Joint for Cars |
Hello Jürgen!
Thank you for your detailed description! Could anyone perhaps offer photos or similar? You mention that these joints are relatively easy to replace. And you also write that this three-arm piece is pressed onto the end of the drive shaft. How is that to be reconciled (just out of curiosity)?!
Take care.
dirk
Translated on 29-09-2026, 16:10.
Jürgen Guest
14-01-2004, 13:21 Subject: Tripod Shaft: Universal Joint for Cars |
'So far, I have been removing the tripods using a puller (after removing the...'
(Retaining rings!) removed, and then with the help of a large nut.
It hit the tightly secured shaft. Of course, pressing would be a natural solution.
nicer. You have to make sure that the nut doesn't get caught in the rollers.
When striking, make sure the tripod remains in contact with the surface, otherwise it might come loose.
So far, this has always worked very well, and I have never...
I experienced that these tripods eventually failed - they all stopped working.
It will take a long time. Relevant images can be found in most repair manuals.
instructions.
Translated on 29-09-2026, 16:11.
Ernst S. Guest
16-01-2004, 13:03 Subject: Tripod Shaft: Universal Joint for Cars |
Does anyone happen to have any photos or similar items for sale?
In the photos, you can see a disassembled tripod joint and, for comparison, a 6-ball joint (also known as a CV joint).
Regarding the tripod joint, it's important to note that with a front-wheel-drive system, it can only be used on the differential side and not on the wheel side. This is because the tripod joint cannot be steered as far as would be necessary for steered wheels.
The tripod joint is simpler to manufacture and is usually also lighter when designed to handle the same torque as a constant velocity (CV) joint.
Ernst.
| Description: |
| File size: |
7.85 KB |
| Viewed: |
4203 times |
| Description: |
| File size: |
7.4 KB |
| Viewed: |
4370 times |
Translated on 29-09-2026, 16:13.
joergs Guest
16-01-2004, 13:26 Subject: Tripod Shaft: Universal Joint for Cars |
That was the principle behind the articulated wave system in the good old Wartburg car.
Translated on 29-09-2026, 16:14.
16-01-2004, 22:13 Subject: Tripod Shaft: Universal Joint for Cars |
Hello!
Great!!! Thank you everyone for answering all of my questions so thoroughly!!!
bye
Dirk.
