Where is the original timer relay for the STH system located in the A6 (profile)?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
durnesss
Post16-01-2004, 22:27    Subject: Where is the original timer relay for the STH system located in the A6 (profile)? Quote
Since I don't have access to the files yet...
Could someone please check where the Webasto timer is located?
'for vehicles that are equipped with it from the factory.'
The recommended location is to the left of the steering wheel, below the tachometer.
It looks like it was 'cobbled together,' does it have to be like that?
Thank you in advance, Thomas.
davidshoes
Karma: +6 / -2   Thank you, like it!
Post17-01-2004, 11:41    Subject: Where is the original timer relay for the STH system located in the A6 (profile)? Quote
To my knowledge, there are two versions.
The first one: In the driver's side compartment, in the first small storage compartment (where the seat memory controls are located).
The second one: next to the handbrake in the small storage compartment, it looks like the controls for the small navigation system, with a display in the FIS (which probably can't be retrofitted).
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BKC Motor: LLK Location & Installation Guide Diesel Engine Technology
No new posts Coolant sensor location ARL: Find it here! Diesel Engine Technology
No new posts Wo sitzt die Staudruckklappe beim Golf III? Transmission, Chassis, Body & Interior
No new posts Golf 4: Location of Distance Sensor Diesel Engine Technology
