edgar-s Guest
27-01-2004, 20:23 Subject: Side panel removal: Door won't open |
Looking for a tip on how to remove the side window when the rear door is locked. Reason: the door cannot be opened, but the linkage is still moving.
It appears that the aggregate carrier cannot be removed without also removing the disk.
Next, I hope to access the lock mechanism and unlock it from the inside - or does anyone have a different idea?
Thank you, Edgar.
Translated on 07-09-2026, 16:53.
christians Profi-Schrauber
27-01-2004, 21:03 Subject: Side panel removal: Door won't open |
I would partially disassemble the intact door on the opposite side to get my bearings. Perhaps you can use a wire to reach parts of the lock between the glass and the door frame if you know where you need to go. Gruß Christian
98er_alh Blaumann
27-01-2004, 21:35 Subject: Side panel removal: Door won't open |
I may not fully understand the problem, but perhaps this will help?
Andreas.
Translated on 07-09-2026, 16:54.
