VW Passat: Climatronic Problems & Solutions
ross10_2
Post06-02-2004, 20:57    Subject: VW Passat: Climatronic Problems & Solutions Quote
When I turn on the climate control, it starts to squeak, very loudly, regardless of engine speed. After 5-10 minutes, the noise disappears. Sometimes, it starts again at random. When switching to 'Econ' mode, the noise also disappears. Since I am currently in Austria and only come home on weekends, I cannot choose a VW workshop in Germany. Everything is more expensive here than at home. Can someone at least discuss the possible cause? So that I can also participate in the conversation during the workshop visit. icon_redface.gif
Translated on 17-08-2026, 18:36.
WarLord
Post06-02-2004, 23:00    Subject: VW Passat: Climatronic Problems & Solutions Quote
Has the air conditioning system ever been refilled? I also have (or had, damn leaky air conditioning icon_evil.gif) a similar squeaking sound, but only when idling.
Best regards, WarLord.
Translated on 17-08-2026, 18:38.
ross10_2
Post07-02-2004, 0:02    Subject: VW Passat: Climatronic Problems & Solutions Quote
No, it wasn't filled yet. The system is supposed to be icon_lol.gif MAINTENANCE-FREE! icon_lol.gif, right? By the way, what does it cost to have it filled here?
WarLord
Post07-02-2004, 9:56    Subject: VW Passat: Climatronic Problems & Solutions Quote
'Hmm, I have no idea what it costs for you. It always depends on the type of refrigerant used. I once got quotes from various places and services for my Passat 35i TDI, and it turned out that VW wasn't the most expensive. Bosch was the most expensive at €106, followed by VW at €80. Then, a guy who also works on air conditioning systems filled it for me for €50. Unfortunately, it's empty again now, so I need to find the leak. By the way, nothing is maintenance-free with this system; the refrigerant leaks through the seals and rubber hoses, sometimes even through a defective heat exchanger or radiator. If the system had been filled recently, I would have assumed that whoever filled it simply forgot to add the refrigeration oil. But now it's probably a faulty bearing on the compressor.'
Translated on 17-08-2026, 18:39.
Post08-02-2004, 19:45    Subject: VW Passat: Climatronic Problems & Solutions Quote
Or the belt tension is too low...
Translated on 17-08-2026, 18:40.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Passat 3B Transmission, Chassis, Body & Interior
No new posts Problem with Passat Climatronic 1996 On-Board Diagnostics (OBD)
No new posts Passat Wiring Diagrams: Climatronic 35i Diesel Engine Technology
No new posts Climatronic Passat 3BG - Correct refrigerant charge at ATU? Transmission, Chassis, Body & Interior
