Buy V6 TDI 4Motion: Best Deals & Reviews
Sniper3
Post04-02-2004, 7:28    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
Hello. I have the opportunity to acquire a 1-year-old Passat Variant V6 TDI 4-Motion at a relatively affordable price. Since I have no experience with this car or engine, I wanted to ask you experts what things one should pay attention to when buying such a car. Or is the car, the engine, or the drivetrain so prone to problems that it's best to avoid it? Oh, and it has a manual transmission and 150 horsepower. Thank you very much for your help.
Translated on 21-08-2026, 4:01.
Julian
Post04-02-2004, 9:26    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
Translated on 21-08-2026, 4:02.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post04-02-2004, 12:41    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
So, the engine is definitely great. However, it consumes a bit too much fuel for my taste.
Okay, but it's all a matter of opinion.
Common engine problems I've encountered include the exhaust wheel detaching from the turbocharger.
Otherwise, I'm not aware of anything else.
But especially in the 4Motion combination version, it's extremely heavy and consumes a lot of fuel.
Accordingly. You'll definitely be the envy of everyone in the winter.
If the price is right, I would buy it.
Translated on 21-08-2026, 4:03.
Sniper3
Post04-02-2004, 14:20    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
Okay, the price is really excellent. It's one year old, fully equipped, has 10,000 km on the odometer, and costs €26,900. This puts it significantly below other prices you can find, for example, on mobile.de.
I hadn't even thought about the fact that it's heavier. Does that have a significant impact on performance compared to a 2WD vehicle?
Translated on 21-08-2026, 4:04.
Tagessuppe
Post05-02-2004, 9:13    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
Given the price, I would definitely go for it.
It's almost €20,000 cheaper than the list price (I assume because of the extras).
A well-equipped car will certainly bring a lot of joy in the long run.
And I probably don't need to say anything about the 4Motion system.
Translated on 21-08-2026, 4:05.
Wurstblinker
Post05-02-2004, 12:58    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
'At that price, I would first check to see if the mileage is genuine. Tampering with odometers isn't a big deal anymore; even dealers do it, I've seen it myself (with Defenders).'
Take a look at the tires; after 10,000 km, they still have quite a bit of tread left.
Regarding the Quattro's extra weight: You will only notice it if you have a direct comparison with a 2WD vehicle.
My father owns an A4 with a PD engine and 96 kW front-wheel drive, and another A4 with the same engine and 96 kW quattro all-wheel drive. He doesn't notice much of a difference himself, but he also tends to drive more conservatively.
A fellow student drives a V6 TDI 110kW with Quattro in an A4 and is very happy with this combination. He gets around 8 liters per 100 kilometers with normal driving.
Sausage blinkers.
Translated on 21-08-2026, 4:07.
Stefan .
Post06-02-2004, 19:15    Subject: V6 TDI Engine: Performance & Specs Quote
So, the engine itself is actually quite impressive when it's running properly.
Whenever possible, you should definitely buy the car with a used car warranty. Even small repairs can cost a lot of money, not to mention the mass airflow sensors, which are supposedly now supposed to last forever...
The Passat V6 TDI 4-Motion is essentially a Quattro, meaning the technology largely originates from Audi rather than Volkswagen.
Regarding the weight: I own a 1999 Audi A4 12/98 (VIN <200,001), AFB V6 Quattro with full equipment (including tow hitch), and according to the TÜV scale in October 2003, it weighed approximately 1710 kg with a full tank.
Speeding is no problem; it also handles corners really well, but the weight makes braking quite difficult.
To address this, I installed larger brake discs on the front axle (312mm instead of 288mm), which made it much more tolerable; also, the wear is reduced.
Regarding tuning: I got a chip from Noth**le back then and I'm very happy with it, except for the soot coming out of the exhaust. It runs very smoothly and easily. The advertised power output was 180 hp and 370 Nm, but the car actually exceeds those figures (measured). However, I can always swap the chip back to the original one; which is what I always do before visiting a workshop.
Regarding fuel consumption: I rarely manage to achieve 8 liters per 100 kilometers, regardless of whether the car has a performance chip or not; closer to 9 liters, or even 9.5 liters, is more typical, with an 80/20 ratio of highway to city driving.
However, I've heard that the new engines are significantly more fuel-efficient.
icon_wink.gif Stefan.
Translated on 21-08-2026, 4:10.
WarLord
Post06-02-2004, 19:26    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
Okay, I have a question: What is the basic front-to-rear torque distribution ratio for Quattro and 4Motion systems?
Best regards, WarLord.
Translated on 21-08-2026, 4:13.
Stefan .
Post07-02-2004, 21:48    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
The forum search function is your friend...
50:50 under normal conditions; up to 75:25 or 25:75 as needed.
WarLord
Post08-02-2004, 20:31    Subject: Buy V6 TDI 4Motion: Best Deals & Reviews Quote
Okay, because I read in another forum that syncro has a basic distribution of 90:10.
Translated on 21-08-2026, 4:14.
No new posts Documented clutch failures in 4-Motion TDI-PD engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Used TDI Buying Guide: Tips & Tricks Diesel Engine Technology
No new posts Polo Blue Motion: BMS System Upload
No new posts Golf 4 ARL: Installing a Parking Heater On-Board Diagnostics (OBD)
No new posts Golf 5 2.0 TDI 4-Motion rear brake caliper Transmission, Chassis, Body & Interior
