kapselchrissi Guest
26-07-2003, 14:06 Subject: Coolant fan control unit??? |
hey folks,
I have a wiring diagram for a Climatronic in a Golf III 96 lying here and I'm about to lose it. I'm looking for the control unit for the cooling fan. It should have 2 fuses (20A and 30A), as well as a 10-pin connector and a 4-pin connector. It's important because it's also connected to the magnetic coupling for the air conditioning system. Thanks.
mersente Guest
10-02-2004, 22:52 Subject: Coolant fan control unit??? |
Hello, please follow the cable from the fan or the thermistor on the cooler.
Where it is located is the control unit.
Martin R Guest
11-02-2004, 20:21 Subject: Coolant fan control unit??? |
The control unit should be located near the coolant overflow tank.
