Whistling Noise 1.9 TD (AAZ) Engine
Dieselpilot
Post19-09-2003, 20:23    Subject: Whistling Noise 1.9 TD (AAZ) Engine Quote
hi,
I drive a Golf III 1.9L TD with the AAZ engine.
The following problem has occurred: The engine has been making a whistling or humming noise at low RPMs for some time now. It's barely audible inside the car, but if you stand next to the vehicle, you can hear it quite clearly.
Meine Frage: was könnte da die Ursache sein? Damage from improper storage?
This is already my second engine; in the first one, a connecting rod bearing shattered and shot through the engine block.
Of course, I've also done quite a bit of performance tuning (increased fuel injection, a different nozzle for turbocharger pressure enrichment, more turbocharger pressure, intercooler, etc.).
Translated on 05-10-2026, 3:18.
mersente
Post10-02-2004, 21:11    Subject: Whistling Noise 1.9 TD (AAZ) Engine Quote
A whistling sound likely originates from a leak in the turbocharger's pressure system or from the turbocharger itself.
Translated on 05-10-2026, 3:19.
Post12-02-2004, 9:49    Subject: Whistling Noise 1.9 TD (AAZ) Engine Quote
Hi Dieselpilot,
"Try using the search function."
If there are no leaks and the loader isn't consuming any oil, I would just ignore it.
I've already tried several chargers, but I couldn't find any defects on the pipes.
If the charger is broken, it might make a whistling sound, but conversely, just because it's making a whistling sound doesn't necessarily mean it's broken.
Translated on 05-10-2026, 3:20.
palmstrollo
Post12-02-2004, 23:53    Subject: Whistling Noise 1.9 TD (AAZ) Engine Quote
Perhaps also a Spanish-style roll from Lima?
Hermann.
mersente
Post13-02-2004, 20:43    Subject: Whistling Noise 1.9 TD (AAZ) Engine Quote
Okay, then spray some Caramba or something similar on it, and that should make the noise disappear, at least for a while.
Translated on 05-10-2026, 3:21.
haehnlein
Post14-02-2004, 0:19    Subject: Whistling Noise 1.9 TD (AAZ) Engine Quote
Hold the exhaust pipe. If you hear a hissing sound, the exhaust system has a leak, which makes the turbocharger whistle very audible!
____________
Kein Auto mehr!
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log files related to the "thinking pause" issue when acce... Upload
No new posts "Chip tuning" only possible with the original tuner On-Board Diagnostics (OBD)
No new posts Engine Misfire: Starting Issues & Troubleshooting Diesel Engine Technology
No new posts Snorkeling / "Kaudern": known. TDI AWX error? Diesel Engine Technology
