Replace Fuel Injectors: DIY Guide & Tips
kossmann
2016 Audi Q3
Post11-03-2004, 17:09    Subject: Replace Fuel Injectors: DIY Guide & Tips Quote
Hello everyone,
It's time - the needle valve actuator will be replaced, but:
- Can the nozzle block be replaced by the user, or is specialized equipment required, and/or does it require adjustments afterward?
- Shouldn't all four injectors be replaced at once after 150,000 km to ensure a consistent spray pattern? Otherwise, the other three would likely be much more worn than the new one.
Are there any prices available for these Bosch parts (which I have already selected) for an Audi 80 Avant, 1.9 TDI (B4, 1Z), manufactured in March 1994?
0 432 193 829 - Nozzle with NBF coating.
0 432 193 838 - Nozzle
Based on what I've read so far, other (larger) nozzles probably aren't recommended, right?
Thank you!
Translated on 25-07-2026, 20:58.
kmrlange
Post11-03-2004, 19:54    Subject: Replace Fuel Injectors: DIY Guide & Tips Quote
I had my Audi AEL injectors checked at a Bosch service center yesterday (at 165,000 km).
Result: The opening pressure is only approximately 170 bar. The target value is 190 bar!
In each nozzle, at least one of the five holes was blocked.
So, I'm having them serviced at a Bosch service center. The wear parts will be replaced.
Cost factor: approximately €90 per nozzle (€45 for materials). After that, they are equivalent to a replacement nozzle from the official supplier. This offers a price advantage of about €100.
Best regards, KAi.
Translated on 25-07-2026, 21:01.
christians
Post11-03-2004, 21:34    Subject: Replace Fuel Injectors: DIY Guide & Tips Quote
The tool is basic: search function.
With me, the new injectors caused a misadjustment of the injection timing.
Therefore, I would not replace a single nozzle unless the injection pressures and spray pattern have been demonstrably verified as being correct.
Gruß Christian
Translated on 25-07-2026, 21:02.
Post12-03-2004, 16:55    Subject: Replace Fuel Injectors: DIY Guide & Tips Quote
Prices (for a single coil in a Golf 3).
VW Replacement Parts:
Items 1, 2, and 4: 100 EUR each.
€3.19
That's €493.
Asked 3 days ago.
Translated on 25-07-2026, 21:03.
kmrlange
Post12-03-2004, 20:27    Subject: Replace Fuel Injectors: DIY Guide & Tips Quote
for your information:
hab jetzt die Rechnung von Bosch: 1 AEL Düse überarbeitet runtergerechnet 79,-EUR icl. Sexpensive.
Best regards, KAi.
Translated on 25-07-2026, 21:04.
No new posts Interesting for all Passat owners from 1996 onwards. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku alle VAG Fahrzeuge MJ 2002, Kühlmittelverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DIY Turbo Repair: Save Money & Time? Diesel Engine Technology
No new posts Audi A4 B7 Timing Belt Replacement and Adjustment - DIY ... Diesel Engine Technology
No new posts Combine two Webasto's into one? On-Board Diagnostics (OBD)
No new posts Flexible pipe broken again! Should all engine mounts be r... Transmission, Chassis, Body & Interior
