Intake Manifold Removal: How To & Tips
Post11-03-2004, 14:03    Subject: Intake Manifold Removal: How To & Tips Quote
Hi.
When I remove my intake manifold, verschandeln it, and reinstall it, what parts should I replace, and how should I treat them?
- New poetry is clear.
- How can I somehow lubricate a gasket?
- New screws???
- Should screws be greased? Yes/No?
Thank you.
Translated on 07-08-2026, 1:52.
mersente
Post12-03-2004, 0:48    Subject: Intake Manifold Removal: How To & Tips Quote
Hello Martin, You can reuse everything and don't need to oil or grease anything.
You can reuse the insulation material yourself, as long as it remains intact during removal.
Translated on 07-08-2026, 1:53.
haehnlein
Post12-03-2004, 20:38    Subject: Intake Manifold Removal: What Now? Quote
dieselmartin wrote:
- New screws needed??? - Should the screws be greased, yes/no??
Hi Martin,
Applying a bit of anti-seize compound to the threads will work wonders when you need to remove the screws next time. This stuff is truly a lifesaver, especially for aluminum threads that tend to seize up.
____________
Kein Auto mehr!
Translated on 07-08-2026, 1:54.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Oil proliferation in the ASZ. Incorporate PDEs and images Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Replacement: Bolts Too? Diesel Engine Technology
No new posts ESP vom AKE in den AKN Motor einbauen Diesel Engine Technology
No new posts VW 2,4 AAB --> Kompressor einbauen!? Diesel Engine Technology
No new posts Install water pump, but how? Diesel Engine Technology
