Increased Fuel Consumption After 30,000 Miles
mp090779
Post03-02-2004, 9:49    Subject: Increased Fuel Consumption After 30,000 Miles Quote
Vehicle: Skoda Fabia Estate/Wagon, 1.9 TDI (PD).
I'm creating a fuel consumption statistic based on mileage and fuel used. Before the service, my average consumption was 4.8. Since the service (at 30,000 km), I've had a consumption of 5.6 over the last 5,000 km. The consumption has increased significantly since the service. I changed to winter tires 14 days prior, but there was no noticeable change in consumption.
Does anyone have any ideas? Could something have been adjusted during the service?
Okay, here's the translation:
Thank you.
Peter MH.
Translated on 02-11-2026, 18:42.
Post03-02-2004, 9:55    Subject: Increased Fuel Consumption After 30,000 Miles Quote
Besides the usual maintenance items, was anything special done during the service, such as the timing belt?
Has the car been performing worse since then?
Otherwise... https://community.dieselschrauber.org/en/viewtopic.php?t=5016
Translated on 02-11-2026, 18:43.
mp090779
Post03-02-2004, 10:28    Subject: Increased Fuel Consumption After 30,000 Miles Quote
The service was standard and didn't include anything special. The performance hasn't changed significantly.
Unfortunately, I can't find anything helpful using that link (maybe it's the wrong number?).
Thank you, Peter MH.
Translated on 02-11-2026, 18:44.
Post03-02-2004, 15:17    Subject: Increased Fuel Consumption After 30,000 Miles Quote
"It's quite strange, actually. What kind of oil was used? But that certainly wouldn't account for a 15% increase in fuel consumption."
Translated on 02-11-2026, 18:45.
Markus H.
Post03-02-2004, 20:05    Subject: Increased Fuel Consumption After 30,000 Miles Quote
Are you sure you're not drawing a false correlation between consumption and service?
It seems that winter actually started around the time your car came in for service.
Based on my experience, I can say that my TDI consumes more fuel in the winter than in the summer (despite having air conditioning). It's about 0.5 liters per 100 km.
mp090779
Post03-02-2004, 23:29    Subject: Increased Fuel Consumption After 30,000 Miles Quote
Regarding the oil: this car has only ever used oil from DEA.
I also suspected a connection between the service and the winter conditions, which is why I had the car serviced after 5000 km. In the summer, the average fuel consumption was around 4.5 (using Poly 5). Currently, it's at 5.6. In the fall, we even had trips with two bicycles on the trailer, resulting in a fuel consumption of 5.5 over a total distance of 1000 km.
From your questions, I gather that it's impossible to accidentally change anything in the engine's electronics. With the fuel injection system on my scooter, I can adjust the characteristic parameters using a diagnostic tool. This seems to be impossible with a TDI engine.
Peter MH.
Translated on 02-11-2026, 18:47.
Post04-02-2004, 8:59    Subject: Increased Fuel Consumption After 30,000 Miles Quote
Do you rely on the MFA (Multifunction Display) reading for fuel consumption, or do you calculate it yourself each time you refuel? Just a question, because there might be something wrong with the diagnostic reading from the VW (or Skoda) device... it's unlikely, but possible. Otherwise, I can't really imagine such a drastic increase in fuel consumption. Besides, my 96kW car always uses around 5.5 liters in everyday driving, and 4.5 liters would require a significant effort.
Translated on 02-11-2026, 18:48.
mp090779
Post05-02-2004, 23:26    Subject: Increased Fuel Consumption After 30,000 Miles Quote
I always calculate fuel consumption based on the distance traveled and the amount of fuel used. The only information I take from the MFA (Multi-Function Display) is the average speed.
Now that it's getting warmer again, and I'm planning to do my usual 500km ride this weekend, let's see what happens.icon_rolleyes.gif
Peter MH.
Translated on 02-11-2026, 18:49.
juergen908
Post06-02-2004, 0:12    Subject: Increased Fuel Consumption After 30,000 Miles Quote
I'm not sure, but an improperly performed air filter replacement might dislodge dust in the air duct near the mass airflow sensor (MAF), which could then contaminate the sensor.
In other forums, it's also noticeable that the mass airflow sensor (MAF) often fails shortly after reaching 30,000 miles.
If you have reference values, you should measure the voltage at the mass flow meter (MFM) at maximum power and check if it is below the normal value.
Does anyone have reference voltages here?
Jürgen
Translated on 02-11-2026, 18:50.
juergen908
Post06-02-2004, 0:14    Subject: Fuel Consumption Increased After 30,000 Mile Service Quote
Vehicle: Skoda Fabia Estate 1.9 TDI (PD).
Peter MH
Oops, is it available as a PD?
What power output, what letter code?
Translated on 02-11-2026, 18:51.
Post06-02-2004, 7:07    Subject: Fuel Consumption Increased After 30,000 Mile Service Quote
mp090779 wrote:
Does anyone have an idea?
Here's something to look at:
... just an idea... If there are any leaks somewhere, the consumption will change drastically, but not necessarily the performance.
Translated on 02-11-2026, 18:52.
mp090779
Post17-03-2004, 14:01    Subject: Increased Fuel Consumption After 30,000 Miles Quote
So, it seems the temperature is really the culprit when it comes to energy consumption. Since last weekend, I've been back to roughly my previous consumption levels – more or less abruptly. I'm going to try to statistically record the temperature during my trips.
However, the difference of almost 1 liter seems a bit high to me. I was also used to the fact that the fuel consumption changed with the tire change in my old Golf II (1.8 gasoline engine), but it was not affected by the temperature.
I will post this again when I have more statistics available.
Peter MH.
Translated on 02-11-2026, 18:53.
bloeckler
Post18-03-2004, 19:01    Subject: Fuel Consumption Increased After 30,000 Mile Service Quote
juergen908 wrote:
Peter MH
Sure, we have the icon_wink.gif.
Mine is an ATD EZ 11/01 - 74kW TDI-PD model. The 96kW version is called the RS, but it's only available as a sedan.
Translated on 02-11-2026, 18:54.
Gremlin
Post18-03-2004, 20:22    Subject: Fuel Consumption Increased After 30,000 Mile Service Quote
Peter MH
Sure, here's the translation:
'ei freilisch...'
'ei freilich' translates to 'indeed' or 'certainly' in English.
-> www.skoda.de
Click on the Fabia RS as well. Is it the counterpart to Ulf's Polo? icon_wink.gif
CU Gremlin.
Translated on 02-11-2026, 18:56.
donalexo
Post18-03-2004, 20:43    Subject: Increased Fuel Consumption After 30,000 Miles Quote
as well.
... and RS then stands for Racestraint, right?
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 02-11-2026, 18:57.
Post19-03-2004, 20:23    Subject: Increased Fuel Consumption After 30,000 Miles Quote
donalexo wrote:
... and RS then stands for Race streamer, right?
No, for Right Seriously :twisted:heavy }.
Polo, 96 kW, unladen weight = 1155 kg.
Ibiza, 96 kW unladen weight = 1192 kg.
Fabia RS, unladen weight = 1245 kg.
(Catalog data)
Translated on 02-11-2026, 18:58.
No new posts CNG service reset, gas tank Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Service Interval Display / Maintenance Indicator Technical Data
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Increased fuel consumption after MFA following AGR decomm... Diesel Engine Technology
No new posts Service reminder does not expire after WIV reset. On-Board Diagnostics (OBD)
No new posts Starting difficulties/high fuel consumption; cleaned afte... Diesel Engine Technology
No new posts Service interval reset VW T6 On-Board Diagnostics (OBD)
