WFS after engine conversion
Basti
Post31-03-2004, 19:47    Subject: WFS after engine conversion Quote
My friend converted his Vento from a 1Z model (without WFS) to a PD model (with WFS).
Now the question is, what do we need to get the car running?
He got a combination instrument panel for the engine that's from a Passat 3BG, and we found an engine control unit on eBay. Now, how do we connect everything and what else do we need?
Thank you for any help.
Sure, here's the translation of the German text "cu basti" into English:
"cu basti" is a greeting that is used in some parts of Italy. It is similar to the English phrase "see you later."
Cu Basti
Back to top Profile PM Email
mersente
Post31-03-2004, 20:25    Subject: WFS after engine conversion Quote
You'll probably need a reading coil and a matching transponder (from a key of the immobilizer generation). Then you'll need to wire everything correctly, and finally, you'll need to adapt the immobilizer to the engine control unit and pair the key with the immobilizer.
joergs
Post31-03-2004, 20:26    Subject: WFS after engine conversion Quote
Take a look at the DRV page and read it. You should find everything you need there!
http://www.vcds.shop/index_2.html
Then, select examples and then choose the corresponding document!
Good luck.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2.5 TDI ACV: Engine Remap After Conversion On-Board Diagnostics (OBD)
No new posts AGR to ALH Engine Swap: Throttle Pedal Issues On-Board Diagnostics (OBD)
No new posts A3 2.0 TDI Engine Swap: Guide & Tips On-Board Diagnostics (OBD)
No new posts Engine Swap AFB to AKN Diesel Engine Technology
