Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5?
Mat
Post09-04-2004, 10:31    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
Hello everyone!!!
I'm getting my new Golf Sportsline with 105 horsepower next week!
I was wondering if it's still possible to bypass the EGR valve, as it was with older TDI models, without triggering any error messages? Does the trick of disconnecting the clutch connector still work?
Sure, no problem.
Best regards, mat.
Translated on 08-07-2026, 6:26.
Post09-04-2004, 19:36    Subject: Re: Disconnecting the AGR valve on a 105PS PD engine from a Golf 5??? Quote
Mat wrote:
Next week, I'm getting my new 5-series Golf Sportline with 105 horsepower PD!!!
wollte mal fragen ob es wie bei den alten tdis auch möglich ist die agr abzuklemmen OHNE DAS FEHLERMELDUNGEN AUFTRETEN? funktionert der trick mit dem kupplungstecker auch noch???
Based on my "only Euro 3-compliant" car, which triggers the error light even with a dead AGR (though thankfully doesn't go into limp mode), I suspect you're in a similar situation.
But what exactly do you mean by disconnecting the clutch connector (what for??) icon_eek.gif icon_question.gif
Translated on 08-07-2026, 6:27.
mersente
Post09-04-2004, 19:52    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
Hello, It's not that simple to disable the AGR (selective catalytic reduction) system, as it is monitored as part of the OBD (on-board diagnostics) system for diesel vehicles, which is installed in the Golf V.
So, the MIL (Malfunction Indicator Lamp, which is the check engine light) will start to stay on continuously.
It will likely soon be possible to prevent this through the use of fake information.
Translated on 08-07-2026, 6:28.
Avatar-Jan6K
Post09-04-2004, 21:02    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
I think what's meant by the clutch issue is that he wants to disconnect the connector from the clutch switch and ensure that the MSG (presumably a control module) always sees "clutch not depressed."
That would negate the shock absorption and would likely provide a bit more acceleration when starting hard, but it would also likely damage the clutch and transmission more quickly.
I would avoid doing that, especially since it's not great even when using cruise control.
Jan.
1Z5 CFHF / AHB H4D
Translated on 08-07-2026, 6:29.
Post10-04-2004, 8:15    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
mersente wrote:
Hello, It's not that easy to disable the AGR, as it is naturally monitored as part of the OBD system for diesel engines, which is installed in the Golf V.
Da wird es sicherlich auch bald möglich sein das durch einen Fake zu unterbinden.
The principle would be quite simple: mix the EGR control signals, in a "smoothed" form, with the mass airflow sensor (MAF) signal.
I've been thinking about a circuit design that would accomplish this with the least amount of effort... but I haven't found a truly convincing solution yet.
Translated on 08-07-2026, 6:31.
SeatArosa1.7SDI
Post10-04-2004, 8:48    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
'Umm, I don't want to interrupt your 'smoothed-out malfunction lamps' icon_wink.gif, but how about simply inserting a metal plate between the EGR valve and the intake manifold? It's a purely mechanical solution that has been proven thousands of times.'
Or is the volumetric flow rate of exhaust gases already being monitored by an air mass meter (AMM)?
Or does the engine control unit already trigger a warning if the mass airflow sensor value becomes suspiciously high (because there is a lack of exhaust gases and therefore more air is being drawn in)?
Translated on 08-07-2026, 6:32.
Avatar-Jan6K
Post10-04-2004, 9:29    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
@SeatArosa{m Exactly. That's why the question at the beginning, and that's why Ulf's considerations. Newer TDIs will detect it if you disable the AGR valve. It's quite simple - if the AGR control system doesn't cause a change in the mass airflow sensor (MAF), then something is broken.
@Ulf: I know you don't like digital technology... but a small AVR microcontroller could do a great job.
Jan.
1Z5 CFHF / AHB H4D
Translated on 08-07-2026, 6:33.
SeatArosa1.7SDI
Post10-04-2004, 9:54    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
I thought so. Clever, those guys at VAG icon_wink.gif.
But there is still a purely mechanical solution:
The EGR valve no longer mixes exhaust gas into the intake air, but instead introduces fresh air. It's essentially a switched bypass for the mass airflow sensor (MAF). This would likely require a small, separate air filter.
Well, I think the electronic solution would be more feasible with less effort. A small analog circuit with 10 components on a stripboard the size of a matchbox – and that's it. It's just about artificially attenuating the analog signal from the flow meter.
Translated on 08-07-2026, 6:34.
Mat
Post10-04-2004, 10:21    Subject: Can you disconnect the AGR (Automatic Gearbox) from a 105hp direct-injection (PD) engine of a Golf 5? Quote
Thank you for the quick responses!!!
Okay, I thought that the AGR issue wouldn't be that simple! If it can only be fixed with a correction circuit, I'll probably leave it for now (because of the warranty and so on...).
@ jan6k, yes, you are right, that's what I meant. However, I don't believe that it's harmful in any way. This type of damping wasn't used anywhere before. According to VW/Audi group, it only serves as a comfort function to prevent rattling.
Best regards, mat.
Translated on 08-07-2026, 6:36.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Golf 5 105PS: Engine Management System Diesel Engine Technology
No new posts 105PS TDI: Questions and Answers Diesel Engine Technology
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
