Vacuum Pump Test: How to Check & Repair
x world one
Post18-04-2004, 22:02    Subject: Vacuum Pump Test: How to Check & Repair Quote
How can you test the vacuum pump on a TDI engine?
Is this even possible? The pump is supplying pressure to the BKV.
"I'm now experiencing a very loud humming or rattling noise when the car is stationary. However, this noise only occurs when the brake pedal is pressed! Based on this, I suspect it might be the vacuum pump. The workshop mentioned that the gears might have play on the intermediate shaft, which could be causing the rattling. But could it also simply be the pump itself? I'd like to have it checked, especially to see if there's still enough vacuum pressure for the brake booster."
Thank you.
Spritmonitor
Translated on 22-10-2026, 19:06.
x world one
Post20-04-2004, 21:02    Subject: Vacuum Pump Test: How to Check & Repair Quote
Has icon_sad.gif anyone ever had a problem with the vacuum or vacuum pump?
Spritmonitor
Translated on 22-10-2026, 19:07.
Gremlin
Post21-04-2004, 8:20    Subject: Vacuum Pump Test: How to Check & Repair Quote
So far, the problems have been limited to the O-ring for the Zyko.
CU Gremlin.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Problem: Faulty Vacuum Pump? Transmission, Chassis, Body & Interior
No new posts Fuel Pump Removal: AJM Engine Guide Diesel Engine Technology
No new posts How to check the GRA function? Diesel Engine Technology
No new posts How to inspect the tie rods on a G IV. Transmission, Chassis, Body & Interior
