Servo Oil Temperature: How Hot Can It Get?
Post18-04-2004, 21:00    Subject: Servo Oil Temperature: How Hot Can It Get? Quote
I found it amusing that the T5 has an extra ribbed servo cable running in front of all the other three coolers (LLK, AC, water).
Now I've seen that the pipe connecting the storage container to the pump in the G3 is also referred to as a "cooling pipe."
As it is currently positioned (in the slipstream of the engine carrier), it won't be able to cool very effectively!
How hot does the liquid inside actually get?
Reason for this question:
/viewtopic.php?t=5111&highlight=servo öl
Okay, here's the translation:
Thank you.
Translated on 23-10-2026, 9:16.
carstenAFN
Post18-04-2004, 22:22    Subject: Servo Oil Temperature: How Hot Can It Get? Quote
Hello Martin,
Yes, I also noticed at the junkyard that many cars have a loop in the metal pipe in the front area, especially smaller Japanese cars had this (I was looking for a piece of servo hose icon_smile.gif). It seems to be a normal solution. My Saab didn't have it, and the power steering has already been running for 420,000 km without an oil change...
"In the rear of the T3 VW bus, the sauce gets so hot that you can still touch the hose carefully, although I don't know what it's like at the front or what it looks like when driving at full speed. In the original design, there are also metal pipes there, perhaps for cost reasons."
hello
Carsten.
Translated on 23-10-2026, 9:17.
Uwe
Post18-04-2004, 23:11    Subject: Servo Oil Temperature: How Hot Can It Get? Quote
Das Problem ist nicht der normale Fahrbetrieb, sondern die außergewöhnliche Bedienung durch den Fahrer, wenn er die Lenkung voll einschlägt und in dieser Stellung festhält. Dann wird das Öl gekocht, da die Pumpe laufend Leistung bringen muss.
Da macht schon es Sinn, etwas Kühlung zu haben.
Gruß Uwe
Translated on 23-10-2026, 9:19.
Julian
Post20-04-2004, 21:12    Subject: Servo Oil Temperature: How Hot Can It Get? Quote
Normal operating temperature range is approximately 40-60°C.
Translated on 03-11-2026, 8:42.
Post21-04-2004, 10:31    Subject: Servo Oil Temperature: How Hot Can It Get? Quote
@UweViewing profile: Uwe:
Dazu passt auch der Warnhinweis im (G IV-) Handbuch, dass der Volleinschlag auf max. 15s zu begrenzen ist, um die Pumpe nicht zu überlasten.
mcgregg
Karma: +7 / -1   Thank you, like it!
Post21-04-2004, 10:40    Subject: Servo Oil Temperature: How Hot Can It Get? Quote
Mein Golf II (MKB PF) zischte am Lenkradanschlag ganz theatralisch, so daß ich ihm das höchstens 2 Sekunden zumuten mochte. Mein Octavia macht das nicht. Und hat auch ein Kühlrohr. Ob das allerdings zur Servolenkung gehört, dazu fehlte mir die Muße, das herauszufinden.
mcgregg
Skoda Octavia II Combi TDI, 2012, 103kW/140PS MKB CFHC
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Hot Brakes: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts How hot does servo oil get? Diesel Engine Technology
No new posts VW T4 Multivan 1997 - Heater not working Transmission, Chassis, Body & Interior
No new posts Diesel Engine Misfire: Why It Happens & Fixes On-Board Diagnostics (OBD)
