PD Errors: Common Mistakes in [Your Field]
Post11-04-2004, 10:16    Subject: PD Errors: Common Mistakes in [Your Field] Quote
I've incorporated a few PD updates into the technical articles about common causes of errors (3 instances of idle surging and a camshaft that was incorrectly set from the factory, "mine").
I would especially like those with expertise in Parkinson's disease to read through this and provide corrections, additions, etc., so that the entries can be as practical as possible.
Thank you icon_smile.gif.
Translated on 22-10-2026, 21:20.
Post12-04-2004, 16:48    Subject: Common Mistakes: PD Article Update Quote
ulf wrote:
I would especially like to ask those with expertise in PD (Parkinson's Disease) to read through this and provide corrections, additions, etc., so that the entries can be made as practical as possible.
Not today, and not the same tomorrow.
I just got back from vacation, and my car's fuel consumption has gone crazy again! It's using 10.5 liters per 100 kilometers, even at a speed of 93 km/h (with a trailer). icon_rolleyes.gif
Translated on 22-10-2026, 21:22.
WarLord
Post12-04-2004, 18:09    Subject: PD Errors: Common Mistakes in [Your Field] Quote
Best regards, WarLord.
Translated on 22-10-2026, 21:23.
Post12-04-2004, 18:28    Subject: Common Mistakes: PD Article Update Quote
Bertil wrote:
...my car's computer icon_rolleyes.gif has driven me crazy again... 10.5 liters per 100 kilometers... at a speed of 93 km/h (with a caravan attached)...
"Yes, I've noticed the same thing. As soon as I give it a little bit of gas (just briefly!), the average fuel consumption for that trip (usually 20-25 km per trip) jumps up so quickly and dramatically that you have to drive slowly, at 60-70 km/h in 6th gear, for quite a few kilometers to bring it back down."
Currently, I would find it very interesting to compare the efficiency curve diagrams of a VP (variable valve timing) and a PD (port design) engine. I'm increasingly suspecting that the fuel consumption in the power and torque ranges, where only PD engines can reach those levels, increases disproportionately compared to VP engines }.
Translated on 22-10-2026, 21:24.
Post12-04-2004, 18:57    Subject: PD Errors: Common Mistakes in [Your Field] Quote
WarLord wrote:
No, not necessarily.
The 1Z was too light, and because of that, I didn't get approval to drive it at 100 km/h. So, I never had the opportunity to drive that van very fast.
Under similar load and driving conditions, the AXR requires only slightly more power, but it also climbs hills more easily. Or has someone removed the Kassel hills (A7 Werratalbrücke towards Kassel)?
The problem with comparing consumption figures lies precisely there. I can climb hills much faster, and the air resistance is already quite significant with a caravan.
Ulf wrote:
...I'm increasingly suspecting that the consumption in the power and torque ranges, where only the PDs can operate, is increasing disproportionately compared to the VPs
That is quite possible. The turbo diesel is becoming increasingly similar to the gasoline engine.
Translated on 22-10-2026, 21:26.
Thomas
Post13-04-2004, 13:08    Subject: PD Errors: Common Mistakes in [Your Field] Quote
Hi Ulf,
I re-read the article.
I only noticed the "Rr".
Symptome: Gelegentliches bis häufiges "hartes" Rruckeln, oft nur in bestimmten Drehzahlbereichen. Engine
Otherwise, I could also imagine a situation where there is some white smoke coming out after starting the engine.
Check and, if necessary, replace the glow plugs. I recently had this problem, and replacing the glow plugs solved it!
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 22-10-2026, 21:28.
Post13-04-2004, 19:49    Subject: PD Errors: Common Mistakes in [Your Field] Quote
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Check the glow plugs and replace them if necessary. I just had this problem, and the new glow plugs solved it!
Hi Thomas,
The "Rr" has been corrected icon_lol.gif.
The issue with the white smoke is already covered in the technical article about preheating system startup problems.
Based on general experience, glow plugs do not last for the entire lifespan of a motor.
Faulty spark plugs are most likely to become noticeable during cold starts in winter.
The engine is difficult to start and/or runs roughly for the first few seconds.
Often, white to bluish exhaust fumes are emitted.
Actually, I would like to avoid repeating the same information in multiple articles, because the collection already offers enough reading material and entertainment (for beginners) icon_wink.gif.
Translated on 22-10-2026, 21:29.
Thomas
Post13-04-2004, 20:25    Subject: PD Errors: Common Mistakes in [Your Field] Quote
Hi Ulf,
Okay, I wasn't aware of that. I thought I had read something about it in the forum before.
But as you can see from the example, I don't have a complete overview either!
If I think of anything else, I'll let you know.
See you later.
Greetings.
Thomas.
Translated on 22-10-2026, 21:31.
mcgyver2k
Post13-04-2004, 21:54    Subject: Common Mistakes: PD Article Update Quote
ulf wrote:
Currently, I would find it very interesting to compare the efficiency curve diagrams of a VP (variable valve timing) and a PD (port design) engine. . . I'm increasingly suspecting that the fuel consumption in the power and torque ranges, where only PD engines can reach, increases disproportionately compared to VP engines icon_evil.gif
I can help you with efficiency calculations.
http://free.pages.at/mcgyver2k/diagrammpd96kw.jpg
Hopefully, the image will upload correctly.
But maybe that's interesting in itself.
Translated on 22-10-2026, 21:32.
Post14-04-2004, 17:23    Subject: Common Mistakes: PD Article Update Quote
mcgyver2k wrote:
With the efficiency of PD, I can help....
Great, thanks in advance icon_smile.gif.
I have another PDF with various diagrams related to the Industrial Variable Pitch TDI AFD (60kW at 3300 rpm).
It includes, among other things, the energy balance, but apparently only at full load (so, no shell diagram).
The Q-effectiveness (presumably referring to the useful power output) is approximately 41 kW at 2000 rpm, and the upper curve (Qrest) reaches about 97 kW at 2000 rpm.
41 / 97 = 0.422 -> This indicates the same efficiency in the maximum Nm range as the PD motor.
At 3300 rpm, the air-fuel ratio (AFD) is 0.372, which is slightly worse than the PD engine.
Therefore, it cannot be concluded that the PD motor has a higher specific (full-load) consumption compared to the VP motor, assuming my interpretation of the AFD's energy balance is correct.
Translated on 22-10-2026, 21:34.
joergs
Post14-04-2004, 19:14    Subject: Common Mistakes: PD Article Update Quote
I just got back from vacation, and my car's fuel consumption has gone crazy again! It's using 10.5 liters per 100 kilometers, at a speed of 93 kilometers per hour (with a trailer). icon_rolleyes.gif
Oh dear! And I thought I was the only one who needed 10 liters with the car! I just came back from Croatia and I also used an average of 10 liters! icon_evil.gif
Translated on 22-10-2026, 21:36.
Post15-04-2004, 8:31    Subject: Common Mistakes: PD Article Update Quote
joergs wrote:
Truck traffic reduced to 9.0, with sections partially free of trucks (approximately half the distance is clear). Average speed is 9.9.
This clearly demonstrates the difference in fuel consumption between driving at 86-88 km/h in a truck convoy versus 100 km/h without a truck escort.
All speeds were determined using a navigation system (GPS). The measurement error is less than 1 km/h. My vehicle is approved for a maximum speed of 100 km/h... so I haven't done anything illegal!
Translated on 22-10-2026, 21:38.
joergs
Post15-04-2004, 8:44    Subject: PD Errors: Common Mistakes in [Your Field] Quote
aha!
'I didn't experience much of a speed difference with the truck in bulk mode. In Germany, on the highway, an average speed of 85-90 km/h felt a bit slow. In Austria, the speed limit is 80 km/h anyway, so the trucks were faster there. Then, the sometimes steep and winding roads in Slovenia and Croatia added to the problem. It's quite annoying to constantly have to shift between the 1st and 3rd gear for kilometers.'
I haven't done anything illegal either, as I also have an official speed limit of 100 km/h for the combination (vehicle and trailer).
Translated on 22-10-2026, 21:39.
Mampf
Karma: +8 / -1   Thank you, like it!
Post21-04-2004, 16:35    Subject: PD Errors: Common Mistakes in [Your Field] Quote
joergs wrote:
aha!
... in Austria, the speed limit is only 80 km/h, so the trucks are often faster than the cars.
I haven't done anything illegal either, because I also have an official speed limit of 100 km/h for the combination.
On "in. at" roads, cars and light trailers (braked or unbraked, maximum authorized gross weight <= 750 kg, combined weight of vehicle and trailer max 3500 + 750 kg) are allowed to travel at 100 km/h on highways and federal roads. For heavy trailers (braked, maximum authorized gross weight <= the unladen weight of the towing vehicle, the sum of the maximum authorized gross weights of the towing vehicle and trailer <= 3500 kg), the speed limit is 80 km/h on federal roads and 100 km/h on highways.
If my understanding of the regulations for vehicles with a maximum authorized speed of 100 km/h in Germany is correct, then the towing vehicle must be at least 20% heavier than the trailer, and the total weight must not exceed 3500 kg (please correct me if I am wrong). Therefore, in Austria, you would have been allowed to drive at 100 km/h on the Autobahn.
Munch.
Translated on 22-10-2026, 21:41.
joergs
Post21-04-2004, 17:03    Subject: PD Errors: Common Mistakes in [Your Field] Quote
sorry,
I unfortunately fell victim to misinformation from a large German automobile club. Sadly, I received this information in written form in the travel kit and also had it confirmed verbally. I unfortunately couldn't double-check it online, otherwise I would have noticed the contradiction. But that's life...
Translated on 22-10-2026, 21:43.
Post21-04-2004, 20:16    Subject: PD Errors: Common Mistakes in [Your Field] Quote
.... Yes, close but not quite right... icon_wink.gif http://www.kues.de/gespann/AusnahmeVO9StVO.htm
Translated on 22-10-2026, 21:44.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.6l CR-TDI, frequent regeneration / Diesel particulate f... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts LLK Article Update: Latest Insights & Trends Diesel Engine Technology
No new posts P1640 Error After Update: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts CUPA: Frequent Regnerations - Causes & Solutions Diesel Engine Technology
No new posts VAGCOM Update: 607.3 to 704.1 On-Board Diagnostics (OBD)
