Repaint car
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
G3-TDI
Post16-07-2002, 0:12    Subject: Repaint car Quote
Hello, has anyone here ever had their car repainted?
I have a red Golf 3 and I would like to repaint it silver metallic. Since I'm getting a complete light leather interior, it will look very elegant.
Okay, if it's excessively expensive, I definitely won't get it. It was just something to consider as a way to invest my vacation bonus money.
and do you have to take everything apart for that, or how does it work?
Translated on 15-07-2026, 16:40.
Post16-07-2002, 9:21    Subject: Repaint car Quote
It really depends on your requirements.
Is it okay if the car has a different color on the outside, and if the edges around the windows aren't perfectly clean, then taping will suffice.
However, this is only recommended for truly old cars (e.g., repairing and restoring a rusty car that's over 10 years old).
It looks neat if you remove all the trim pieces and rubber seals.
"Perfect condition (like a new car) is extremely expensive because absolutely everything needs to be removed."
As a rough estimate, you should budget around €3000 for a reasonable (i.e., mid-range) paint job, including the paint itself.
It's crucial to thoroughly verschandeln and roughen up the old paint; don't cut corners here (because if you rush, you might end up with a new coat of paint that peels in places, revealing the old paint or primer underneath, and you'll have wasted your time and money).
Everything else looks like a complete mess due to the lack of working time and the resulting inability to disassemble parts.
Doing it yourself would be the cheapest option if you don't need your car for two weeks, have enough time, and already have some painting experience. If you've only painted small parts before, it's probably not recommended; you shouldn't necessarily start with the most challenging project.
If you consider your golf to be in the "under 1000 Euro car class" (although that doesn't sound very appealing), then this would be a good way to practice and gain experience.
Translated on 15-07-2026, 16:43.
G3-TDI
Post16-07-2002, 19:08    Subject: Repaint car Quote
Hmm, I think my Golf is more in the €5000 range icon_smile.gif.
I'll get some quotes.
Although, for me, 3000 euros is definitely too much.
But thank you for the initial overview.
Translated on 15-07-2026, 16:45.
No new posts Automotive Technology: Topics & Resources Technical Articles
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Golf V - Automatic Lock and Automatic Unlock On-Board Diagnostics (OBD)
No new posts Hi-tech car, low-tech workshop? Diesel Engine Technology
No new posts Auto-Lock etc Diesel Engine Technology
No new posts Crap electronics in the car Diesel Engine Technology
