AUDI A4 V6 TDI AFB BJ.1998 dreht nur bis 3000U/min und Rauch | Posts 16+
Go to page: Previous  1, 2
volker32
Avatar-volker32
Post03-06-2004, 12:05    Subject: Quote
Unfortunately, I have to disagree with Markus. The AKN engines also have the same problem with the camshafts as the AFB. A friend of mine also had to replace the camshafts in his car. It had a mileage of 143,000 km and was manufactured in 2000.
So, from that perspective, the AKN doesn't seem to be significantly better either.
Volker
Translated on 20-09-2026, 20:18.
seabauer
Post03-06-2004, 15:35    Subject: Price Monitoring: Track & Analyze Prices Now Quote
...thank you for the advice, I will check again to see if it's progressing.
and obtain a written cost estimate icon_rolleyes.gif.
Is €550.00 a reasonable amount for the repair? According to the BOSCH technician...
It's a problem with the pump's control unit.
Let's see...
Best regards, Helmuth.
PS: To top it all off, the airbag light was also on icon_redface.gif.
Apparently, there's an intermittent contact problem under the seat. The error memory has been cleared, and everything is working again (hopefully, until the next time).
Translated on 20-09-2026, 20:20.
knubbi
Post05-06-2004, 18:58    Subject: Quote
Hello Seabauer!
'The people at Bosch often say it's a problem with the control unit. I wouldn't rely on that being the error, though.'
It took me 4 hours to replace the pump myself. It's a really unpleasant job. However, I wouldn't necessarily be willing to pay €550 for someone else to do it (unless I was absolutely sure it would solve the problem).
No one can guarantee that, though. (See my experience – it was a disaster.)
Hi Knubbi,
Translated on 20-09-2026, 20:21.
seabauer
Post09-06-2004, 7:51    Subject: Pump Replacement: Cost, Types & Installation Quote
Finally, a car that revs up to 4500 icon_biggrin.gif.
The fuel injection pump seems to be stuck somewhere, possibly on the magnetic sensor.
There were iron shavings present on the spur gear.
According to Bosch, it might have been water that caused the pump to 'fail.'
led.
The 'new' pump was priced at €550.00 plus €162.00 for labor. The old one is being repaired. Was the price reasonable?
Okay, so the interesting thing was, there was a Vectra 2.0 DTI and a 320d in the workshop, both with a faulty fuel pump. Do these also use a VP44 pump (is that only for 6-cylinder engines or?)
Translated on 20-09-2026, 20:23.
knubbi
Post09-06-2004, 20:36    Subject: Quote
That means you only paid 550 euros for the replacement pump?
And only €162 for the installation????
Are these DREAM PRICES???!!!!!
Translated on 20-09-2026, 20:24.
No new posts Coolant Leak: A4 8D Doku, Up to Week 45/1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine RPM Limited to 3000, Excessive Smoke Diesel Engine Technology
No new posts ASZ Full Load Adjustments: 1700-3000 U/min Diesel Engine Technology
This topic is locked, you cannot edit or reply. Uneven acceleration from 3000 RPM Diesel Engine Technology
No new posts ALH Engine: Performance Issues Above 3000 RPM Diesel Engine Technology
