Leichtes Ruckeln zwischen 3000 und 4000 U/min Hilfe!!! | Posts 32+
Go to page: Previous  1, 2, 3
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Post21-06-2004, 12:40    Subject: Quote
PrivatBereich wrote:
MTM A6 2,5 TDI wrote:
Do you now understand that "tools" in this context refers to the diagnostic software from here and a laptop, which I don't have and won't buy because of a problem.
@MTM A6 2.5 TDI:
It would be enough if you purchased the adapter kit for 69 euros and borrowed a laptop with a COM port from a friend. You don't need to buy your own right away! And I think 69 euros is reasonable, considering how much Audi has already added to the price.
If you don't happen to know anyone who has a laptop (which I find hard to believe), then the cheapest one you can find on eBay for under €150 should suffice.
Private
Post21-06-2004, 12:46    Subject: Quote
And look: For measurement block "Injection Start" (which was measurement block 3), according to the table, it should have a value of AT LEAST 70 and AT MOST 82.
Mine fluctuated between 60 and the highest it ever showed was 63!!! (measured at idle)
Measurement block 3 contains the values for the mass airflow sensor, not for the start of injection.
"Also, there's also a missing piece of information: how the value was measured (e.g., using a default setting or not)."
Therefore, your post is completely useless.
[EDIT: Incorrect table linked]
http://www.dieselschrauber.de/Solldaten_5_Zylinder_VE.html
Please provide the text you would like me to translate from German to English. I will then provide the translation without any explanations.
Apart from that, if the measurements were taken in operating mode and idle mode, the values in measurement block 0 would be acceptable.
I don't think it makes sense to waste any more time on your problem.
You have three options: either take matters into your own hands, continue spending money at your incompetent repair shop, or find a different repair shop.
No new posts Draft Test / Performance Test 2000-4000 rpm Technical Articles
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Light vibration between 3000 and 4000 RPM! HELP! SOLUTION! Diesel Engine Technology
No new posts Minor jerking, not engine-related! Transmission, Chassis, Body & Interior
No new posts Jerky Acceleration: Causes & Fixes Diesel Engine Technology
No new posts ATD: Engine Jerking at 1000-1500 RPM Diesel Engine Technology
