I'm afraid I'm having a problem with my clutch. Recently, I've repeatedly noticed that when starting slowly in second gear, the clutch doesn't always disengage properly. After a long highway drive in stop-and-go traffic, it even got to the point where the clutch didn't disengage at all several times in a row, and as a result, the gear couldn't be taken out. The problem only occurs in second gear and is not yet reproducible every time. I also get the impression that the clutch has occasionally 'rubbed' when engaging for about a year.
What could this indicate...? Thank you for any tips; I have also searched extensively and haven't found anything similar in the database yet....
Thank you in advance.
Hey guys.
Golf IV, ALH engine, 120,000 km, manufactured in 1999, mostly used for long distances.
