Sharan: Check Engine Performance After Injector Replacement
gg-flitzer
Post22-06-2004, 19:53    Subject: Sharan: Check Engine Performance After Injector Replacement Quote
I installed 216 injectors and new software in my Sharan.
'I'm not quite sure how to proceed with this test; can someone help me?'
Combat weight including driver: 1800 (weight taken beforehand).
gangway extension 1.3448
Axle reduction ratio: 1:4.235
tires 195 15 65
Acceleration from 40-80 km/h in 3rd gear, at 2000-4000 RPM: 4.9 seconds.
gg-flitzer
Translated on 11-09-2026, 5:50.
Arne
Post23-06-2004, 8:21    Subject: Sharan: Check Engine Performance After Injector Replacement Quote
Hmm, what's the problem there? Let's start with your standard car model.
- Please enter values into the yellow-highlighted fields at the top.
- Afterwards, find the torque value for your engine at the very bottom of the list and enter it into the yellow fields labeled 'Original Torque.'
Now you have the time of the original Sharan...
Simply enter a percentage value in the 'Engine Power Increase (Tuning, etc.)' field until the time you calculate matches the time highlighted in blue, and then check the 'Actual Engine Power' field to see how much power you have.
arne
Translated on 11-09-2026, 5:52.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Nozzle Replacement: How to Properly Secure Diesel Engine Technology
No new posts High fuel consumption after timing chain replacement Diesel Engine Technology
No new posts Ash loading value not reset after DPF replacement On-Board Diagnostics (OBD)
No new posts ABS Light On After ESP Change - No Codes? On-Board Diagnostics (OBD)
