AGR Valve issue on AAT - Need assistance
Audi2,5TDiDriver
Post30-06-2004, 20:10    Subject: AGR Valve issue on AAT - Need assistance Quote
I've tried using the search function, but I only ever read the descriptions. However, since I'm not very familiar with the AGR and its surrounding components, I would appreciate some pictures showing exactly what you mean by 'a thin metal plate.' I can't imagine how and where.
Please help me, because the coughing is also getting worse for me. I now have about 200,000 km on the odometer. Also possible via email.
For any assistance, thank you.
Best regards
Nico
Gremlin
Post01-07-2004, 5:39    Subject: Re: AGR Valve issue with AAT - need help Quote
a few pictures showing exactly what you mean by 'a thin metal plate'. I can't imagine how and where.
instead of the gasket, use a GASKET (without the large hole in the middle icon_wink.gif) between the AGR fitting and the pipe to the exhaust system.
See you, Gremlin
No new posts What is the synchronization angle in a TDI engine? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: DPF (Diesel Particulate Filter) Problems in ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Control unit, need help!!! On-Board Diagnostics (OBD)
No new posts Leistungsverlust 1z - brauche Hilfe bei VAG-COM On-Board Diagnostics (OBD)
No new posts Getriebe 6 Gang 02m brauche Hilfe Diesel Engine Technology
No new posts Climatronic defekt, brauche dringend Hilfe!! On-Board Diagnostics (OBD)
