VTG Rod Adjustment: VNT17 Installation Guide
dj1
Post01-07-2004, 8:22    Subject: VTG Rod Adjustment: VNT17 Installation Guide Quote
I plan to replace my VNT15 with a VNT17 in 2 weeks icon_biggrin.gif.
I've read a lot about the VTG standard here.
I got the turbo directly from Garrett.
My question: Do I need to adjust anything on the VTG (Variable Turbine Geometry) shaft now, or can I simply install the turbo as is?
DJ.
Vehicle: Volkswagen Golf III, AFN engine.
Translated on 24-08-2026, 9:11.
dj1
Post02-07-2004, 8:10    Subject: VTG Rod Adjustment: VNT17 Installation Guide Quote
Where are the FREAKS!?!??!?! icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Translated on 24-08-2026, 9:12.
Post02-07-2004, 9:41    Subject: VTG Rod Adjustment: VNT17 Installation Guide Quote
... Now I have read a lot about the VTG standard here.
icon_idea.gif Since you've already read so much, you should have a general idea of how it works icon_razz.gif.
But just for you, here's a short version:
-> Install the charger, connect the LDA (if not already connected), and ensure it is not excessively damped.
-> Gently warm up the engine and while doing so, observe any excessive oscillations in the LDA (if present, adjust the rod to be longer).
-> With the engine warmed up, apply full throttle from various points within the power band.
If the pressure fluctuations are greater than approximately 0.2 bar, rotate the rod again.
If the usual pressure builds up significantly slower than expected, rotate the rod for a shorter duration.
Everything is done in steps of approximately 0.5 rotations.
Translated on 24-08-2026, 9:14.
Post02-07-2004, 9:44    Subject: VTG Rod Adjustment: VNT17 Installation Guide Quote
What can one say icon_eek.gif? If it works, there's nothing to adjust; otherwise, the search function provides more than enough information.
Translated on 24-08-2026, 9:16.
dj1
Post02-07-2004, 11:23    Subject: VTG Rod Adjustment: VNT17 Installation Guide Quote
Okay, let's just leave it as is, as it comes from Garrett, and test it?
DJ.
Post02-07-2004, 13:16    Subject: VTG Rod Adjustment: VNT17 Installation Guide Quote
dj1 wrote:
So, let's just leave it as is for now, the way it comes from Garrett, and test it?
Yes.
Translated on 24-08-2026, 9:17.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts VTG Rod Adjustment: Recommended 85% Duty Cycle Diesel Engine Technology
No new posts VNT17 Turbo: Price & Specs Diesel Engine Technology
No new posts Which charging cable or adapter for VNT17? Diesel Engine Technology
No new posts VTG Rod Shortening: Loader Overload Issues? Diesel Engine Technology
