TDI Golf III: Performance Loss Troubleshooting
pg2
Post09-07-2004, 15:28    Subject: TDI Golf III: Performance Loss Troubleshooting Quote
Regardless of the engine speed, my Golf noticeably loses power after accelerating to approximately 120 km/h. Further acceleration is only possible on a flat surface or downhill. The effect seems to be related to the speed: everything is fine below 120 km/h, even at high engine speeds. If I accelerate aggressively, the problem occurs as early as around 100 km/h, but if I drive more cautiously, I can reach approximately 140 km/h.
So far, I have already done/checked:
All sensors and injectors have been tested with a multimeter. All are working correctly and receiving voltage. The fuel filter has been drained: it was empty of water.
Exhaust gas recirculation (EGR) valve: After manually actuating it several times, it became easier to move, and I was also able to move it (slightly) by pulling on the vacuum hose.
A friend read the error codes.
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
Once, a weasel chewed on an air hose (for the turbo?), causing similar symptoms, which I investigated but didn't find anything at the time. Could it be that again? Who knows the answer? But: I'm not a complete expert yet, I'm still learning how to work on TDIs. However, I'm not completely clueless. And I'm not a fan of dealerships. icon_smile.gif
Thank you and best regards.
Peter.
Translated on 02-10-2026, 20:03.
Post09-07-2004, 15:39    Subject: TDI Golf III: Performance Loss Troubleshooting Quote
1. Search is your friend!
You can find plenty of information about the 575.
2. If you find an error, then usually do the following:
- Note down errors.
- clear errors
- Test drive (once, if possible, without the problem occurring; once, deliberately provoking the problem).
-> The error should only reappear on the second attempt.
Then you have already proven the connection to the code problem icon_smile.gif.
Then you can investigate the code and its possible causes further (by searching here in the forum).
P.S., very important: Is it a 90 HP or 110 HP engine? This completely changes how the turbocharger boost (manifold pressure) is controlled (again, search for technical articles about vacuum in VP37 engines).
Translated on 02-10-2026, 20:06.
pg2
Post09-07-2004, 15:53    Subject: TDI Golf III: Performance Loss Troubleshooting Quote
Hello Dieselmartin,
Thank you for your reply. It's a 110 horsepower engine. Thanks for the search tip, I'll do some more research. I'll take care of the test drive myself.
Cheers!
Peter.
Translated on 02-10-2026, 20:07.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
No new posts Is it possible to retrofit a VE-ESP system from a Golf 4 ... Diesel Engine Technology
