Cigarette Lighter Lighting: Won't Work with LDA
dj1
Post15-07-2004, 19:55    Subject: Cigarette Lighter Lighting: Won't Work with LDA Quote
I just installed my LDA.
I wanted to use the cable from the cigarette lighter socket to power the lighting for the LDA (likely referring to a specific device or system).
So, I unplugged the connector from the ignition system (the connector has 3 wires) to see which one was for the lights -> it's the blue/white wire.
Okay, LDA lighting cables completed.
Problem: The cigarette lighter and the LDA (License Plate Lamp) are not working.
I've already checked the fuses (number 21 -> cigarette lighter) – they are okay.
The remaining interior lighting is working.
What could be wrong with that?
Please help!
Thank you.
DJ.
Translated on 13-08-2026, 18:23.
Post15-07-2004, 20:36    Subject: Lighter & LDA Lighting: Troubleshooting Guide Quote
dj1 wrote:
What could possibly be wrong with that?
Most likely, your car is currently plotting something mischievous, and you're about to thwart its plans using LDA.
That's why he's now taking revenge with bizarre copper worms...
Seriously, that's a bit too much for me.
Normally, all the instrument panel lighting is connected to one fuse, as far as I know -> either everything works or nothing at all... but it's a different fuse than the one for the "main power" that powers the starter!
Translated on 13-08-2026, 18:26.
dj1
Post15-07-2004, 20:44    Subject: Cigarette Lighter Lighting: Won't Work with LDA Quote
Yeah, I think that's weird too...
Well, I guess I'll have to do a little more searching.
Thank you very much.
Translated on 13-08-2026, 18:27.
Julian
Post15-07-2004, 20:49    Subject: Cigarette Lighter Lighting: Won't Work with LDA Quote
Did you temporarily turn the ignition back on? icon_eek.gif (Silly question, but some comfort control units send signals even in standby mode...)
Dan.jel
Post16-07-2004, 6:47    Subject: Cigarette Lighter Lighting: Won't Work with LDA Quote
Maybe the plug is just loose.
This has happened to me while assembling something before too... icon_wink.gif
Translated on 13-08-2026, 18:28.
dj1
Post16-07-2004, 13:00    Subject: Where to get negative numbers? Quote
Maybe the plug is simply disconnected?
This has also happened to me once while assembling something... icon_wink.gif
Apparently, the coil (from the Zigi) is defective.
Can someone tell me which one is the negative cable?
There are three wires connected to the plug.
DJ.
Translated on 13-08-2026, 18:29.
No new posts A2 Doku: Faulty Combination Light - 8Z0 MJ 2002 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat MJ 2000 Beleuchtung Sonnenblende defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MJ 2002: Flickering Lights & CD Player Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Beleuchtung von Golf IV Tacho nicht mehr so hell! Transmission, Chassis, Body & Interior
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts The pre-heating lamp is not turning off. Motor does not s... Diesel Engine Technology
