Luftdichte-Änderung durch LLK: wie groß?? | Posts 16+
Go to page: Previous  1, 2
chris11
Karma: +3 / -1   Thank you, like it!
Post23-07-2004, 14:02    Subject: Quote
The reasons for choosing intercooling versus increasing boost pressure, in my opinion, are in the following order:
Higher Carnot efficiency achieved by cooling the air before combustion. The pressure increase due to combustion is higher. (This is likely why jet turbines operate so efficiently at -50 Celsius at an altitude of 10km.)
Lower compressor capacity (pressure * flow rate).
This results in reduced thermal stress on the engine and turbocharger components with intercooling.
Christian.
Translated on 25-09-2026, 22:00.
eike
Post23-07-2004, 14:51    Subject: Quote
(Why do jet turbines likely operate so efficiently at -50 degrees Celsius at an altitude of 10 kilometers?)
1. They have no other choice; it's just that cold up there.
2. The air is also much thinner.
3. Who says they actually work efficiently? The movement up there is efficient because the air is so thin, and therefore the air resistance is correspondingly low.
Everything else is probably more a matter of perspective...
Greetings.
Eike.
Translated on 25-09-2026, 22:02.
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hands-free noise in Audi A3 (1996-2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Fluid Change MJ07 to 08 Transmission, Chassis, Body & Interior
No new posts Exterior Change Notification On-Board Diagnostics (OBD)
No new posts Air Mass Meter AJM - Values too high On-Board Diagnostics (OBD)
No new posts Passat AHU: Turbocharger Boost Pressure Too High On-Board Diagnostics (OBD)
