ulf wrote: |
| Gleichzeitig treibt der Mehr-Druck wieder die LLK-Eintrittstemperatur nach oben. |
But only the INLET temperature. After the cooling process, i.e., behind the cooler, the normal conditions are restored. Due to the higher inlet temperature, the efficiency of the cooler even increases, as it operates with a higher temperature difference.
With significantly higher flow resistance, or if there's a valve after the radiator, you'll eventually end up with an air conditioning system.
The only truly relevant parameter in your consideration is likely the increased exhaust backpressure, possibly also the increased operating temperature of the turbocharger, which can affect its lifespan.
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
