PBox: Compatible with ASV, not just AFN?
P!R4Te
Post28-07-2004, 15:57    Subject: PBox: Compatible with ASV, not just AFN? Quote
I have a big problem... A friend of mine is offering me a Pbox for a good price, but it's from a Sharan, which only came with a 110 HP engine (AFN) in that version!
I have a Seat Toledo 1M with the engine code ASV, and I'm not sure if my engine is compatible with this PBox... I don't want to break anything!
Are there any significant differences?
Can someone help me?
Best regards, icon_rolleyes.gif Philipp (Pirate)
Translated on 15-09-2026, 3:03.
Post28-07-2004, 16:05    Subject: PBox: Compatible with ASV, not just AFN? Quote
While the AFN came in various versions, ...
A very simple pre-check:
The AFN model might still have the 8-pin connectors on the pump, while the ASV model definitely has 10-pin connectors.
If that's the case, then there's definitely no plug-and-play functionality.
Translated on 15-09-2026, 3:04.
P!R4Te
Post28-07-2004, 18:27    Subject: SEO: Best German to English Translation Services Quote
Okay, I'll have to try to see if it fits... Do I have a chance?
'In theory, nothing is impossible to break.'
Translated on 15-09-2026, 3:05.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post29-07-2004, 8:40    Subject: PBox: Compatible with ASV, not just AFN? Quote
No, absolutely nothing can break or go wrong there.
I believe both have the 10-pin connector, so it should work.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vag-Com Adapter: Compatible with New Audi A3? Diesel Engine Technology
No new posts Air Mass Sensor: Compatible Alternatives? Diesel Engine Technology
No new posts Does this connector fit a Volkswagen Golf 4? On-Board Diagnostics (OBD)
No new posts Crankshaft Bolts: Problem Also for 1.6TD Engines? Diesel Engine Technology
