dr_braun Guest
28-07-2004, 21:44 Subject: |
'On Thursday and Friday, the actual pressure in the area of 2000-4000 RPM was at least close to the target pressure. I checked this because I wanted to see if the original AFN turbocharger could maintain the pressure, and there were almost no pressure surges. Unfortunately, I can't remember the duty cycle. I'll need to open the MSG (wastegate control solenoid) and check the hose inside, and then I'll create the logs and diagrams.'
Thank you & good night!
Translated on 11-09-2026, 8:12.
dr_braun Guest
29-07-2004, 21:03 Subject: |
'Today was a really stressful day, but I finally got around to checking the logs. Both are in 4th gear, and there's no other option here. Unfortunately, I haven't had time to create any charts yet, but maybe someone would like to take a look. I'll create the charts tomorrow (hopefully I'll have enough time).'
http://www.mxbikes.de/Juli2901.csv
http://www.mxbikes.de/Juli2902.csv
Best regards, Sebastian.
Translated on 11-09-2026, 8:13.
