tdi racer Guest
10-08-2004, 14:32 Subject: Audi 1Z LLK: Coolant Replacement Guide |
Last week, a friend wanted to see my driver's license, and when we checked, I realized I didn't even have one!
I've already used the search function, but I couldn't find anything.
My question is, if I build a replica, will it offer any performance benefits, etc.?
Matthias.
Translated on 04-09-2026, 4:45.
10-08-2004, 15:35 Subject: Audi 1Z LLK: Coolant Replacement Guide |
Who stole your LLK?
Because when your Audi left the factory, it still had one.
Or do you not have a TD__I__, but only a TD (engine code AAZ, 75 hp)?
m; Transparency, Teamwork
Translated on 04-09-2026, 4:46.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
10-08-2004, 15:36 Subject: Audi 1Z LLK: Coolant Replacement Guide |
Okay, search again properly. A 1Z engine definitely has a coolant leak. Check the hoses leading from the turbocharger towards the front of the vehicle!
Wurstblinker Guest
10-08-2004, 19:37 Subject: Audi 1Z LLK: Coolant Replacement Guide |
He is sitting in front of the right front wheel.
You can't see it from below, above, or in front. It's completely blocked by structures.
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which means 'Sincerely' or 'Best regards' in English.
Translated on 04-09-2026, 4:47.
Steffarn Profi-Schrauber
10-08-2004, 20:03 Subject: Audi 1Z LLK: Coolant Replacement Guide |
Wurstblinker wrote: | Hi,
MFG |
Okay, on the A4 1.9 TDI, the component is located on the left side, behind the bumper.
Oops, I don't know which vehicle that is.
 B.Eng (FH) u. KFZ Meister
Profile PM Email Garage |
Sternengucker80 Guest
10-08-2004, 20:33 Subject: Audi 1Z LLK: Coolant Replacement Guide |
Hi!
If it's an Audi 80 TDI, it definitely has one. However, it's not visible from the outside or in the engine compartment. It's located in front of the right front wheel, underneath the crossmember in the engine compartment! It's not positioned in the center at the front, like in the S2 or RS2.
Best, Timo.
Translated on 04-09-2026, 4:48.
Chrizzy08 Guest
12-08-2004, 8:25 Subject: Audi 1Z LLK: Coolant Replacement Guide |
The intercooler (IC) on the Audi 80 TDI 1Z is located behind the bumper. The right air intake leads to the intercooler. If you remove the lower engine cover, you can see the intercooler from the rear.
Hi Chrizzy,
Translated on 04-09-2026, 4:49.
mahk Blaumann
Joined: 08/12/2004 Posts: 121 Karma: +1 / -0 Location: München
12-08-2004, 20:36 Subject: Audi 1Z LLK: Coolant Replacement Guide |
"I'm quite proud of the verschandeln engine bay in my Audi 80 (1989) 1.6 TD (SB). You can see the intercooler from both the top and bottom (provided the lower panel is removed). And, just like yours, it's located in front of the right front wheel."
Translated on 04-09-2026, 4:50.
