Which centering rings for a Golf 3 GT TDI (4-hole)?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
dj1
Post04-09-2004, 20:31    Subject: Which centering rings for a Golf 3 GT TDI (4-hole)? Quote
I have some in sight; they were originally fitted to a BMW E30 with a 4x100 bolt pattern.
Rims: RH Cup rims - 8.5x17 and 9x17.
Since the bolt circle is the same, it only depends on the centering rings of the adapter discs from RH.
The owner said that the centering rings had a size of 57.1.
Will this fit on my Golf 3?
What does this number represent?
Who can help me?
Sure, here's the translation:
'Thank you in advance!'
DJ
PS: Wheel trims will of course still be processed icon_lol.gif.
Post04-09-2004, 21:20    Subject: Re: Which centering rings for a Golf 3 GT TDI (4-hole)? Quote
dj1 wrote:
The owner stated that the centering rings had a size of 57.1.
Most likely, it refers to the diameter of the centering cone – that is, the protruding piece that looks like a small pipe attached to the hub.
57.1 mm might be the right size for the Golf.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Welche Turboladeralternativen beim Audi A4 AFN? Diesel Engine Technology
No new posts _DEFINE0_ Welche Getriebe passen an den AFN im Golf 3?_DE... Diesel Engine Technology
No new posts Rim Width for VW Golf 4: What Fits? Transmission, Chassis, Body & Interior
No new posts Piston hole at cylinder 1 Diesel Engine Technology
