ObenbeiMutti Guest
12-08-2004, 16:04 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
Hello.
Recently, while buying tires...
...I was persuaded by the salesperson's overwhelming arguments in favor of it to get a gas refill  .
Based on his description of the properties, I assumed it was something like xenon atoms or an expensive, high-tech industrial gas with large molecules (which would at least justify the price).
 But, I'm looking at  , nitrogen. Just plain, cheap stuff that surrounds me 70% of the time.
Nitrogen.
After refilling the air at most three times, assuming it's not volatile as promised, there would only be 'noble gas' left in the tire.
I feel like I'm being taken for a fool!
I hope I'm right to feel this way. I would appreciate feedback from knowledgeable forum members who can either support my concerns or offer a more balanced perspective.
Tobi.
Translated on 10-08-2026, 7:36.
Jürgen Guest
12-08-2004, 17:15 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
IMO, this is clearly a rip-off. The nitrogen filling is supposedly intended to prevent pressure loss.
to be minimized. Based on my experience, these issues persist as long as the tires, rims, and...
Valves are usually in good condition, but that's the minimum requirement. In my over 30 years of experience...
It's rare to find a car with a full spare tire. Regularly checking your tire pressure is also important.
Nitrogen filling is essential, and it's also cheaper than these!
'P.S.: For commercial aircraft, the tires on braked wheels must be...'
(For cylinders only connected to the main landing gear), must be filled exclusively with pure nitrogen.
will be implemented. The reason for this is to minimize the risk of fire during heating.
or cause the brakes to overheat. Even with nitrogen filling, periodic...
Tire pressure checks are mandatory - for example, on an Airbus, they must be performed every 72 hours!
Translated on 10-08-2026, 7:39.
Gremlin Guest
12-08-2004, 19:19 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
I always check the pressure whenever there's a significant temperature change.
Since I often cut corners and rush things, even a small amount too much or too little can be noticeable.
Absolutely awesome on the motorcycle...
I think pure N2 is nonsense... if the tire is okay, very little air will leak out. And I'm not going to let some wannabe chemist tell me that I never have to check the pressure again  .
CU Gremlin.
Translated on 10-08-2026, 7:41.
Joined: 04/12/2002 Posts: 18095 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
12-08-2004, 20:46 Subject: Tire Gas Scam or Nonsense? |
ObenbeiMutti wrote: | ...
Nitrogen.
Tobi | .
Hehe
"In my humble opinion, the nitrogen content of the air is actually 78%..."
Translated on 10-08-2026, 7:42.
Profile PM WWW Garage |
Julian Guest
13-08-2004, 8:55 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
It's not worth it. Tire pressure still needs to be checked regularly. And... why pay for something that is freely available at every gas station?
Translated on 10-08-2026, 7:43.
faz Blaumann
1994 Audi 80 Premium Support
13-08-2004, 9:04 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
A small amount of pure nitrogen already makes a difference...
... but only to the dealer!!  MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 10-08-2026, 7:44.
Profile PM Garage |
Gremlin Guest
13-08-2004, 9:21 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
So gesehen... we have a 25,000-liter liquid tank behind the building http://www.cheesebuerger.de/smilies/frech/18.gif.
CU Gremlin.
Bee Guest
08-09-2004, 16:36 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
Hi everyone,
Based on my own experience, I can say that filling with gas really makes a difference!
Or do you want to fill it with water?
Duck and cover.
As I mentioned before: Air contains 78% nitrogen. The remaining molecules are larger than nitrogen. Therefore, it doesn't make sense to me why a nitrogen filling could have any advantages at all. Even if I drive a tire hot: It won't get so hot that it burns. If the brakes are so hot that a tire ignites, the tire doesn't ignite because of the oxygen *in* the tire, but because of the oxygen surrounding the tire.
'Micha'
Translated on 10-08-2026, 7:45.
Forenheini Guest
08-09-2004, 17:49 Subject: Tire Gas Scam: Is It a Ripoff or Nonsense? |
The only physically justifiable advantage of pure N2 would be a slightly better gas constant, but the difference between the gas constant of air and N2 is in the low single-digit percentage range (I'd have to look up the exact value), so it can safely be ignored.
I always follow this motto: If it's free, why not; otherwise, just leave it be  .
Apart from that, the supposedly very pure N2 fillings are also not 100%. After refilling two or three times at the gas station, even with air, there is a significantly higher proportion of N2 in the tire, if you believe the advertising argument about diffusion (oxygen molecules (O2) aren't that small after all...) and think about it logically  .
Translated on 10-08-2026, 7:48.
