Agent 008 is not responding...
TheBeer
Post08-09-2004, 5:29    Subject: Agent 008 is not responding... Quote
Hello!
After I successfully assembled the adapter that Ulf designed...
And as soon as I could, I got my Polo 9N running.
taken.
So far, everything is working as expected with the shareware version of VAG-COM.
as much as possible.
Okay, but now here's my problem: my Climatronic system has been acting up lately.
The fan control display consistently shows the required bars.
on, but the fan periodically oscillates between low and high speeds.
to a speed almost reaching its maximum.
It's only quiet when I manually adjust the climate control, but then it's noisy again after 2-3 [minutes/seconds - context needed].
I can switch back to 'automatic' mode after a few minutes of operation, and it usually works.
Then everything is as desired, but occasionally the device starts acting up after 5 minutes.
start playing with the fan speed again.
So, I was hoping to read the error memory using VAG-COM, but...
The climate control module (ECU) 08 is not responding. After some...
'VAG-COM asks if you want to continue attempting to access the control unit.'
to address the device. That won't achieve anything either.
I received the expression of interest from the workshop regarding the initial inspection there.
is the last entry:
6Q0907044A CLIMAtronic PQ24 0201
Coding 00000 PROG WSC 00000
Well, where it should say 'no error detected,' it's been torn off.
So, the workshop can access the Climatronic system, but I can't icon_sad.gif.
Otherwise, I can access all the control units, such as 01, 46, 44, etc.
just now, but not 08.
Does anyone have any ideas?
Post08-09-2004, 6:18    Subject: Re: Agent 008 is not responding... Quote
"VAG-COM asks if you want to continue attempting to access the control unit."
doesn't achieve anything either.
Most likely, the Climatronic system does not connect to the K-line, but is only accessible via the CAN bus, for example, using an adapter from Rainer's Diagnoseshop.
Yes, yes, brave new world - those who want comfort must also be able to endure suffering sometimes icon_twisted.gif.
But at least now you can access the important STGe icon_lol.gif.
"My" adapter circuits, by the way, cannot be extended to support CAN (I certainly don't know how).
TheBeer
Post08-09-2004, 11:56    Subject: Re: Agent 008 is not responding... Quote
'My' adapter circuits, by the way, cannot be extended to CAN (I certainly don't know how).
Yep, Ulf always has trouble with this modern stuff icon_cool.gif.
I was thinking something like a CAN bus icon_rolleyes.gif.
Okay, I'll think about whether I should go to the new...
Order a suitable CAN interface for the laptop at the same time.
and I was so happy that I managed to get your adapter circuit working.
I have icon_smile.gif.
But for initial testing, it's definitely sufficient.
Uwe@Ross-Tech
Post08-09-2004, 15:56    Subject: Agent 008 is not responding... Quote
A CAN connection is not necessary in a Polo 9N.
-Uwe-
TheBeer
Post08-09-2004, 18:09    Subject: Agent 008 is not responding... Quote
-Uwe-
Hello!
Oh, then there's probably a different problem here icon_cry.gif.
I have performed a self-diagnosis of the Climatronic system.
and there are 3 errors in the memory, but unfortunately, I have...
Don't sugarcoat it.
- 2c6 = ???
- 4F7 = Temperature control flap servo motor 0x25
- 4F9 = Actuator for central valve 0x25.
I have a feeling that '2c6' might have something to do with...
The connection between climate and the diagnostic interface has something to do with icon_rolleyes.gif.
I've already scheduled an appointment with the dealer for Tuesday, as there's still availability.
The vehicle isn't that old; let's see if they can access the error memory.
can be read correctly.
Post08-09-2004, 18:11    Subject: Agent 008 is not responding... Quote
TheBeer wrote:
I have a feeling that "2c6" might have something to do with...
Oha, I completely forgot about the CAN / K-Gateway icon_redface.gif.
Then, of course, the climate control system should also be accessible via the K-Line.
Post08-09-2004, 18:47    Subject: Agent 008 is not responding... Quote
icon_mrgreen.gif http://shop.dieselschrauber.de/product_info.php/products_id/46
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
No new posts Car won't start, lights not working Diesel Engine Technology
