DocSnydor Guest
10-09-2004, 12:53 Subject: Golf 4 Rear Door Won't Close? Fix It! |
My tailgate is very difficult to close. I have to slam it really hard for it to stay closed. Is there a way to adjust this?
There's a rubber buffer inside the lock. You have to press it together by 'snapping' it, so that the latch of the lock engages properly?
Here's a picture of what I'm talking about:
http://mitglied.lycos.de/docsnydor/schloss.jpg
Translated on 09-09-2026, 16:32.
10-09-2004, 13:42 Subject: Golf 4 Rear Door Won't Close? Fix It! |
On either side of the door, there are rubber bumpers that ensure the door rests properly against the car body. These can be "adjusted" by rotating them, which has a significant impact on the door's ability to close. Adjusting these bumpers might be more effective than adjustments to the lock itself.
I was able to eliminate the rattling noise from the rear door by gently tightening certain components.
Jan. 1Z5 CFHF  / AHB H4D
Translated on 09-09-2026, 16:33.
DocSnydor Guest
10-09-2004, 18:57 Subject: Golf 4 Rear Door Won't Close? Fix It! |
Hi Jan,
In the rubber buffers of the golf clubs, there are Allen screws. I've removed them completely before, but it didn't make any difference.
Inzwischen hab ich die Lösung gefunden: Das Gegenstück zu Schloss (in der Ladekante) einfach noch ein Stück weiter nach aussen stellen. Ich hätte nie gedacht, dass das was bringt. Jetzt schliesst die Klappe schon beim leichten Zufallen lassen. Ein Dream...
Have a nice weekend!
David.
Translated on 09-09-2026, 16:34.
Julian Guest
11-09-2004, 9:39 Subject: Golf 4 Rear Door Won't Close? Fix It! |
The flap must fit tightly, otherwise exhaust gases and moisture will leak inside.
Here's a trick (but use it carefully!): Loosen the latch bolt so that it can be moved with some force. Use your finger to close the lock, and then drop the door from about 30cm (1 foot) onto the lock. This will push the latch bolt into the correct position. Tighten the screws on the latch bolt again; that should be enough.
The rubber buffers must be adjusted so that the gap dimensions are correct (as much as possible on a Golf 4). Check this with the flap closed. The gap between the rear light and the roof trim at the top must be of equal width along the entire length.
Translated on 09-09-2026, 16:35.
