Needle Feed Open: Valve/Sensor Status
kossmann
2016 Audi Q3
Post20-09-2004, 17:41    Subject: Needle Feed Open: Valve/Sensor Status Quote
Hello everyone,
My NHG in the 1Z is probably completely broken now... Yesterday, while on the highway, the Audi suddenly went into limp mode, and I had to drive home at 120 km/h. The error code read: "00542 - Needle lift sensor (G80) - 05-00 Input open". A test with an ohmmeter shows 0 ohms... so it doesn't look good at all icon_sad.gif.
Does anyone have any good ideas? Since I'm already constantly looking for cheap AFN nozzles, it's probably time to get some – and that will likely be expensive.
Has dieselsend.de shut down? The website only displays a "Error 404" message.
Where else can you get four new, complete nozzle assemblies for the AFN quickly?
Thank you!
Translated on 15-08-2026, 2:34.
Post20-09-2004, 18:00    Subject: Needle Feed Sensor: Open Input Signal Quote
Tino Kossmann wrote:
Error read: "00542 - Needle stroke sensor (G80) - 05-00 Input open". A test with the ohmmeter shows 0 ohms...
icon_question.gif icon_question.gif 0 Ohms = Short circuit!
An open circuit would have an "infinite" resistance (in Ohms).
How does that all fit together?
Translated on 15-08-2026, 2:36.
kossmann
2016 Audi Q3
Post20-09-2004, 18:23    Subject: Needle Feed Open: Valve/Sensor Status Quote
It could also be very good – the digital ohmmeter showed "0"... but it does that even when you're not measuring anything.
I hereby correct myself to "infinite ohms."
Translated on 15-08-2026, 2:37.
Hati
Post20-09-2004, 18:57    Subject: Needle Feed Open: Valve/Sensor Status Quote
@Tino
dieselend.de is still working...
I'll get back to you tomorrow; I might still have your old NHG lying around in the garage.
Heart.
kossmann
2016 Audi Q3
Post20-09-2004, 19:02    Subject: Needle Feed Open: Valve/Sensor Status Quote
Fact... it's working again.
Okay - thank you!
Translated on 15-08-2026, 2:38.
Gremlin
Post20-09-2004, 21:07    Subject: Needle Feed Open: Valve/Sensor Status Quote
can also be very good - the digital ohmmeter showed '0'... however, it also shows that when you're not measuring anything.
I hereby correct myself to 'infinite Ohms.'
Is it all the way on the left of the screen?
stands for O, representing 'verrun' icon_wink.gif.
It should also display a reading even if you apply 5V to a measurement range that's supposed to be up to 2V.
CU Gremlin.
Translated on 15-08-2026, 2:39.
Hati
Post20-09-2004, 21:25    Subject: Needle Feed Open: Valve/Sensor Status Quote
@ Tino
I actually still have the NHG (National Health Gazette) in the garage; but you also received an email.
Your B4 is therefore almost completely healed icon_wink.gif.
Heart.
Translated on 15-08-2026, 2:40.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Syringe Pumps: Precise Fluid Delivery Systems On-Board Diagnostics (OBD)
No new posts Valve Timing: Open/Closed - Explained Diesel Engine Technology
No new posts Covers off the nebulizers - why? Transmission, Chassis, Body & Interior
No new posts AGR valve open or closed without vacuum hose? Diesel Engine Technology
