ObenbeiMutti Guest
23-09-2004, 12:48 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
Just a random thought, by the way.
I once glanced at the G-meter in a glider that was designed for aerobatics, belonging to our aviation club. Now I've got this idea to retrofit a similar device, but with a shorter and more sensitive scale, into my diesel-powered airplane.
'That way, I always know what's going on. 0.5 - 0.7 G in second gear while passing 2000 RPM should probably be normal. That would always be a good indicator, without having to do a complicated dyno test.'
Has anyone done this before?
Okay, stupid idea, but I'll stick with it  .
Translated on 15-10-2026, 17:32.
Theresias Guest
23-09-2004, 15:02 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
That would also have to work when impacting an obstacle...
Can someone test this  ?
Translated on 15-10-2026, 17:34.
ObenbeiMutti Guest
23-09-2004, 15:07 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
It does it  .
It works from -6 G to  0 G.
You can probably get it for 100 euros.
Problem: The scale and sensitivity for measuring the car are rather inadequate, and it only works with the vertical axis, not the longitudinal or transverse axes, I believe (I'm just guessing).
-then you would have to install it vertically,  perhaps in the dashboard,
A great HUD  illuminates.
WarLord Guest
23-09-2004, 18:35 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
Airbag Output Test.
Yes, and I have tested it before, but unfortunately, I didn't have a G-knife on board at the time.
Best regards, WarLord.
Translated on 15-10-2026, 17:35.
joergs Guest
23-09-2004, 18:38 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
'These sensors, which are installed in vehicles with ESP (Electronic Stability Program), are relatively sensitive. Unfortunately, they are also quite expensive.'
Translated on 15-10-2026, 17:36.
Theresias Guest
Airbag Output Test.
If you do that in the airbag control unit, nothing will happen  .
You should only attempt this on a Touareg (or other newer models), as it's a terrible job to get the car running again afterwards.
WarLord Guest
23-09-2004, 19:09 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
Inwiefern? What's going on there?
Translated on 15-10-2026, 17:37.
Theresias Guest
23-09-2004, 19:11 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
The crash signal triggers a fuse to blow near the battery, but to reset it, you almost have to remove the seat, which requires a special tool...
Meanwhile, it's known how it works, but when it wasn't known yet... well, at least one Touareg vehicle was just sitting there for a while.
Gremlin Guest
24-09-2004, 11:31 Subject: DIY Alcohol Meter: Upgrade Your Still for Accuracy |
Could you please check if you can find any Bosch G-sensors anywhere?
Otherwise, it might be worth inquiring in the measurement technology industry, as there are a large number of micro-mechanical sensors available with digital or linear analog output.
CU Gremlin.
Translated on 15-10-2026, 17:38.
